beemer68 Posted July 8, 2016 Report Share Posted July 8, 2016 INPA Newcastle upon Tyne Link to comment Share on other sites More sharing options...
SmokeyShiva Posted July 25, 2017 Report Share Posted July 25, 2017 Stick me in too, I have INPA with which I can read fault codes and clear some, still learning. Have quite a few more programs but I'm a total noob with them. Northern Ireland, Belfast. Link to comment Share on other sites More sharing options...
Azzabee Posted November 26, 2017 Report Share Posted November 26, 2017 Anyone near Newark Notts that can help me with coding my 2002 330Ci? I’ve just fitted powerfold mirrors and want to get them to fold/unfold when locking/unlocking the car. Thanks in advance Link to comment Share on other sites More sharing options...
Jonnwhite Posted May 20, 2018 Report Share Posted May 20, 2018 North East England Momo: Bradford, West Yorkshire (PASoft and Carly - HOWEVER i'll only do this for forum subscribers (Because I work weekends so i'll have to take time out to read your codes etc..)) Siffion: Teesside INPA/NCS/Carsoft durham4416: Middlesborough chris2r - Sheffield(north), Barnsley and Rotherham - PASoft 1.4 and a Handheld code reader. (not an expert on it!lol) North West England john.med: Warrington, Cheshire. PA Soft 1.4 Rich_D: Lancashire quackers; Bury, Manchester - INPA/NCS Expert/DIS Daza-B - Have all the BMtechnic software installed with cables but not an expert on the software lol - Morecambe Lancashire MaxiB - As above, BMtechnic software and cable. haven't the foggiest how to use it but i'm 'bout to start learning!! Whitchurch, Shropshire. albino-jay: Manchester, INPA, DIS, NCS Expert South West England Quiksilver_TR: SW, Gloucester. (INPA and NCS. Also got separate diagnostic code reader) TriggerFish - Aylesbury, Bucks/Oxford - INPA/DIS/SSS/NCSExpert/PA-Soft-BMW Scanner. 16 pin cars only though. Also got K-Line VAGCOM Gregc: Westbury, Wiltshire (INPA, NCS, GT1, DIS, SSS) East of England Gaz: Milton Keynes, Bucks JasonR: Milton Keynes, Bucks Frobius: Cambridgeshire (INPA, NCS, GT1, DIS, SSS Progman, Tool32, WinKFP) Razza77: Romford Essex. INPA,SSS Progman, DIS, NCS Expert, PA Soft 1.4 FlossRegularly: Braintree, Essex Mikey: Rochester, Kent INPA,SSS Progman, DIS, NCS Expert Trickster: Grays, Essex. INPA, NCS steve-coupe: Dunstable. INPA, NCS Midlands Colossuss: Milton Keynes/Northampton. INPA, DIS, NCS Expert Bob: Burton Latimer/Northants. INPA DIS NCS Expert Chunky: Warwick, Warwickshire (INPA, NCS, DISv57, SSS Progman) Adhal: Stoke-on-Trent/Staffordshire -GT1/DIS/INPA/ Phil67- BMtechnic software and cable but not an expert on the software Carlton in Lindrick, Nottinghamshire Greater London DJ Syxx: NW London (INPA, DIS/GT1, NCS) X-Man: M25 Jct20 (INPA) KASH - Southall, Middlesex - PA Soft 1.4 + (INPA, NCS, GT1, DIS, SSS Progman, Tool32, WinKFP) The_judge aka Suf: Harrow, NW London (INPA, DIS/GT1, NCS) Southern England Chris: Southampton, Hampshire AnalBeard: Gatwick(ish), West Sussex. INPA/NCS Expert Stooza: Horsham and Crawley Down, West Sussex. INPA , EDIABAS , DIS / GT1 (v57) , SSS / PROGMAN (v32) , NCS EXPERT , NAVCODER RoryW Nr Portsmouth, Hampshire - PA Soft 1.4 Missle - Isle of Wight INPA/DIS/SSS/NCSExpert (think i have Navcoder but will have to check!) Ben M -Portsmouth, Hampshire - BMTechnic (INPA/DIS/NCSExpert/NavCoder) Jks87 Guildford PA Soft 1.4 JonnWhite Chichester (Can travel 40 or so miles around area) INPA/NCSEXPERT/TIS/ETK/EBA/Autodata Link to comment Share on other sites More sharing options...
danielukessex Posted December 17, 2018 Report Share Posted December 17, 2018 INPA - Near Chelmsford Essex. Happy to help if you need it, all for the cost of a cuppa!! Link to comment Share on other sites More sharing options...
Sham Posted August 19, 2019 Report Share Posted August 19, 2019 Hi I am new to the forum, I am looking for help/ advise from anyone with INPA/NCS/Carsoft in Lancashire. I am struggling, a number of error codes have appeared on my Dash/idrive. Car is fine drives perfectly, however there are a number of errors constantly flashing. In addition now the cruise control does not work, tyre pressure light remains on even when the pressure is ok and reset, when I switch off engine the coolant warning comes on even though it is full. I can send pictures of other error codes if needed. thank you in advance. Link to comment Share on other sites More sharing options...
robolots Posted September 10, 2019 Report Share Posted September 10, 2019 Anyone in SE Kent, I need my abs ecu matched to my car as it is a replacement. Link to comment Share on other sites More sharing options...
Azzabee Posted April 13, 2020 Report Share Posted April 13, 2020 Can now do INPA, NCS Expert in Newark Notts area, willing to help anyone. After fitting powerfold mirrors way back in 2017 I finally bit the bullet and had a shot at coding on my 330Ci. Just did the beep on lock to start with and it was easy. Now coded beep at lock and unlock and powerfold mirrors also fold/unfold when lock/unlocked. Im gonna have a play with other bits so feel fairly confident. Not sure if it’s ok to post the following here? So apologies in advance if I’m not. I've retro fitted full Sat Nav (Bordmonitor) system including the wiring harness. Also LED rear lights, Bi-Xenon headlights (genuine BMW). LED indicators and repeaters as well as all the interior lights to LED. Aftermarket angel eyes. For info, other things I’ve done: ABS lights (the 3 lights), ABS sensor and reluctor ring replaced. Noisy pulley belts/tensioner. Water pump. Thermostat. Stripped and serviced all brake calipers, fitted grooved drilled discs and stainless braided brake hoses. Replaced both handbrake cables and shoes. Fitted a reversing camera that displays on the bordmonitor. Replaced the radiator and header tank. Got rid of the viscous fan and fitted an electric one. Replaced air con condenser and receiver dryer. Poly bushed front and rear anti-rollbar bushes. Repaired the DISA unit. Replaced all CCV pipes etc. Replaced all 4 shocks. Last job was getting rid of the back box and making new pipes to run 2 twin tailpipes out of the back with a new diffuser. Next job, one touch retract on rear pop out windows, then replace the oil and filter in the autobox. I’m sorry if it’s long winded but shows what can be done without too much hassle. Ive had the car 8 years now, it’s never failed an MOT or had an advisory whilst I’ve owned it, I maintain it religiously and love it to bits. Link to comment Share on other sites More sharing options...
Psc Posted February 15, 2021 Report Share Posted February 15, 2021 (edited) Anyone in Warwick able to code an R50 mini following install of a new Sat Nav screen. Mileage and VIN need correcting. NCS Expert knowledge. Looks like ‘Chunky’ is local but I don’t know how to contact. Any advice welcome. Please PM me. Thanks Edited February 15, 2021 by Psc Update Link to comment Share on other sites More sharing options...
