Rich_D
Turning Off A Remap?
Anyone know if it' possible to disable a remap and revert back to the standard setup, using the software that is readily available?
Or would it need to be done by the mapper?
I know it can be done on some cars, as my mate did it on a remapped Golf using vagcom, but can the same be done with an E46?
All i know is if your car was stock and you remapped it say with Bluefins handheld device, you can revert back to stock then map again as many times as you want.
I'm sure there is some companies out there that can put your map on a handheld device but would need a stock map.
You have to remap it again, but using the original map that your remapper would have saved when doing your remap. Of course if a previous owner remapped it, all you'd be getting would be another remap, but BMW must have the original maps stored somewhere :)
