Paddybrown23
What To Use To Seal Ka Light
My girlfriends ford ka has had a leak in the boot for some time. Found out it's dripping through the rear light so guess the seal has gone. What should I use to re seal it?
Paddy
dont use silicone else youll be stuck forever, get some plumbers mait and roll some out and take light out and fit round edge and put back in, its non setting so can be reused and removed when need be,
Hey Paddy, it's a common problem on KA's. It's usually one of 3 things, Boot seal split, boot handle nuts slightly loose or like you say, rear light cluster seal. Plumbers mate is good but if you still have problems, I have know this leak to be sorted with a bit of caulk of all things :)
If it's been going on for a while, check the earth contacts are not corroded under the light cluster inside the boot also.
Let us know how you get on matey
edited cause I cant speel propurly
Edited by Stooza
