Ashley1995 Posted February 3, 2014 Report Share Posted February 3, 2014 So i bought some CCFL Angel Eyes and installed them as DRLs. I didn't want to tap into the sidelights so i followed this guide made by AnalBeard http://www.e46zone.com/forum/topic/27315-wiring-your-angel-eyes-as-drls/ Then i wanted to have them come on remotely, when i unlock the car. Easiest way to do this is to tap into the interior lights. I tried this without diodes but when the ignition was on it fed back into the interior lights so they where on the whole time. Bare in mind this is for CCFL angel eyes but I'm sure it would work similar to LEDs. Now this is how i did it, basically you want to follow this diagram, but the way you connect it together may be different but this diagram is basically what need to happen. So heres how to do it/i did it: You Need: Angel Eyes 2 x Diodes, I got these - http://www.maplin.co.uk/p/1n5349-brl-12-v-420ma-zener-diode-ay71n Wire Taps/Connectors Some Spare Wire First things first is to install the Angel Eyes into your headlights and run the cables into the ECU box . You need to tap into an earth somewhere, I used a cable in the ECU box. Next tap into the interior lights, easiest place is the passenger footwell as there is access to the ECU box from behind the glovebox. Remove the plastic under the glovebox where the footwell light is and look up towards the engine bay, there is a small half moon shaped hole. tap into the positive feed of the light and feed the wire through this hole and into the ECU box. Next wire in a diode to the wire from the footwell light, and create a wire with a diode in one to connect to the Angel Eyes and tap into the live from the ECU ( Follow above diagram ) Now i the connected all the cables together in a single wire tap, this was the easiest way for me, you may do it differently. I hope that this is not too confusing, if you need help feel free to PM me or whatever. if you have ideas on how to make it simple-er i am all ears. Hopefully this helps some of you - heres a video of it working. shafz, Seb and Rich_325i 3 Link to comment Share on other sites More sharing options...
Chimp Choker Posted February 4, 2014 Report Share Posted February 4, 2014 Just added this to my mod list. Cheers sent with tapatalk pro that mr feva can't use Ashley1995 1 Link to comment Share on other sites More sharing options...
Rich_325i Posted January 9, 2015 Report Share Posted January 9, 2015 Thanks mate Link to comment Share on other sites More sharing options...
touringking Posted January 10, 2015 Report Share Posted January 10, 2015 Mine have been in my headlights now for months, and never wired them up. Time to get them sorted I think Link to comment Share on other sites More sharing options...
