Chrishawker86 Posted March 7, 2015 Report Share Posted March 7, 2015 (edited) Annoyingly it cut out on me on the way home after a long night shift literally 5 minutes walk from my home, I pretty much knew what it was from the way it cut out, and my suspicions were correct when i plugged it in and saw that the air flow meter had failed. What was surprising is that this was only replaced last July with a new part from GSF which cost £120. Would this part still be under warranty? I've not had chance to call as they were closed. Has anyone experienced MAF's failing so quickly? Edited March 7, 2015 by Chrishawker86 Link to comment Share on other sites More sharing options...
pirate1066 Posted March 7, 2015 Report Share Posted March 7, 2015 Always possible,everything is mass produced ,poorly made or substandard part can always slip though,I've had bulbs, ,battery's,crank sensors,plug leads all knackered out the box,aftermarket rotors which break down after a few days ,ive had new rebuild engines let go on the dyno for now reason other than they just went bang. Have a word with supplier they may have had others die ,let them know and how many miles you have covered and how long you've had it fitted,you never know they might be nice and do a deal on replacement ,if ya don't ask you don't get Link to comment Share on other sites More sharing options...
Zonda_ Posted March 7, 2015 Report Share Posted March 7, 2015 Can't see why the car would stop with a faulty MAF, limp home mode yes but not stop, I've had mine running with the MAF completely disconnected. Link to comment Share on other sites More sharing options...
Jay. Posted March 7, 2015 Report Share Posted March 7, 2015 As above, it's probably the pipe work leading to the MAF Link to comment Share on other sites More sharing options...
gamesman2001 Posted March 7, 2015 Report Share Posted March 7, 2015 GFS don't do original parts there all cheap copys I work 40 feet away from the shop they are over priced and crap from there .I got a egr valve from there and still had the same fault as before I put it on told them and as I guest it was a copy..lol guess you know my feelings about them.. Link to comment Share on other sites More sharing options...
Chrishawker86 Posted March 7, 2015 Author Report Share Posted March 7, 2015 (edited) Can't see why the car would stop with a faulty MAF, limp home mode yes but not stop, I've had mine running with the MAF completely disconnected. Yea the car starts when its disconnected first thing i did when i opened the bonnet but runs rougly GFS don't do original parts there all cheap copys I work 40 feet away from the shop they are over priced and crap from there .I got a egr valve from there and still had the same fault as before I put it on told them and as I guest it was a copy..lol guess you know my feelings about them.. Yea think ill try source a second hand OEM part for now Edited March 7, 2015 by Chrishawker86 Link to comment Share on other sites More sharing options...
gamesman2001 Posted March 7, 2015 Report Share Posted March 7, 2015 you in the dale chris? Link to comment Share on other sites More sharing options...
Chrishawker86 Posted March 7, 2015 Author Report Share Posted March 7, 2015 (edited) you in the dale chris? no mate south manchester in Cheadle Edited March 7, 2015 by Chrishawker86 Link to comment Share on other sites More sharing options...
