RoryW
E46 Rca Apple 30Pin Connection - Play Via Aux Input And Charge Simultaneously.
I'm sorry people, I've remove this guide. I'm fed up with 0 posters stubbing across this on google and them joining just to Pm me a question about it.
I don't mind helping the masses out but it's taking the piss now lol
Standing Members feel free to pm me for a guide. But anyone who's joined just to pm me for it will get a rude reply I assure you!
Edited by RoryW
Yeah I have a cable sat here ready so I can do photos start to finish. That cable will do but you will find it will probably only charge 3G iPhone or charge older iPods. The newer generation iPhones need 5v to charge unlike the older 3G where it would allow 12v charging.
That'll be fine though for music etc, I seem to have got lucky and got a cable which allows charging to later iPhones by mistake of the seller so need to update the thread anyway.
The cable you've linked too has the following below about charging. It'll allow music though!
Compatibility:
iPod Video U2 Special Edition
iPod Touch 1st / 2nd /3rd
iPod Nano 3rd / 4rh / 5th Gen
iPod Classic 120GB / 160GB / 80GB / 160GB(lunched Late 2009)
iPod 4th Gen / U2 Special Edition
iPhone 1st / 3G
Apple iPad
Compatibility:
Pod Video U2 Special Edition / 30GB / 60GB / 80GB
iPod Touch 3rd Gen 32GB / 64GB
iPod Touch 2nd Gen 16GB / 32GB / 8GB
iPod Touch 16GB / 8GB / 32GB
iPod Nano 4th Gen. 16GB / 8GB
iPod Nano 3rd Gen 4GB / 8GB
iPhone 3G 16GB / 8GB
iPhone 1st Generation 16GB / 4GB / 8GB
Edited by RoryW
This little pup will charge and play. The cable you linked will audio only but I think I might have a work around so shall have a looksy before posting it.
http://www.ebay.co.uk/itm/RCA-Composite-AV-TV-USB-Charge-Cable-For-iPhone4S-3GS-iPod-Touch-4-Nano-Classic-/130689032157?pt=UK_Computing_Sound_Vision_Video_Cables_Adapters&hash=item1e6dac5fdd#ht_5189wt_1006
Edited by RoryW
http://www.ebay.co.u...#ht_5189wt_1006
nice one Rory, i can do the simple ICE things, i have a oem cd player headunit, no changer. it doesnt have mode on it!
can i still have this cable, so it still works? on oem unit where would the AV leads plug in AS i dont think there are any in the back off it
This cable Pinout won't work for you, if you know what model headunit you have I'll work out what Pinout and cable you need, you might actually get away with a very cheap cable.
I have a cable i think will work for you, once I know the pins you can have the cable cause it'll only end up in the bin if you don't have it.
Also to add the answer to your av question, you'd leave or just cut off the yellow visual cable. The actual RCA plug is cut off these anyway.
Edited by RoryW
@mrmsport
The connectors can be pinched from any old pc case, sure Maplin must sell something similar but haven't had a chance to flick through their catalogue yet.
@Andy
Can you get a picture of the back of your unit. If you have the 2nd set of pins you can use aux input so yes I have an old cable
Also to add, I've ordered a couple RCA cables and plan on doing a proper guide, this was purely written up after Id made sure it worked my end 1st.
Probably be here early this week so I'll crack on with it when it arrives.
Thinking of selling them on? ;D
I'll let the one I make this week for the guide go for a site donation.
Don't know if this site has a donation button??
Looking forward to the pics, been trying to figure out a way to do this for ages!
I have one question though, when installing my satnav retrofit the loom has an adapter in it for aux in which ended up under the trim near the gear stick, Would I be able to use this or will I have to take the cd changer connection out of the back of the screen itself? As it would be much easier to get to the aux in connector than take the screen out.
Thanks
I will make them to order if someone doesn't want to buy soldering iron etc just to make one cable.
If that's not allowed then fair enough, long as no one has a problem with it?
Regarding connections, for the life of me I cannot remember their correct name but here's a quick pic
This is a double connection I just tore from an old workstation.
No, they have a name and also size. I can't remember for the life of me. It's something like female board mount crimp or something stupid like that. I'll crack through the RS catalogue when I'm free later and find some.
Not just pc's that use them, we used to use them in the thousands when making the development gps units at raymarine.
