Wahla Posted June 25, 2020 Report Share Posted June 25, 2020 The passenger chair could be moved back, but not forward, Ok to lean forward but not back, OK to high up but not lower. Now the chair is in back end position so I cannot reach the bolts for the chair to be able to remove it. I have tried to change the control unit with the one from the driver chair but no difference. When pushing the control I can hear relays under the chair clicking, but nothing happens. The fuses in the glove compartment are checked. Any idea what the problem can be? Link to comment Share on other sites More sharing options...
E46Driver330Ci Posted June 25, 2020 Report Share Posted June 25, 2020 Does the "bad" controller work on the good seat? If there is no info available, then taking the good seat off for study might be an option. Then you might be able to find a way to turn the motor manually and move the chair off the bolts. Link to comment Share on other sites More sharing options...
