330iSportMatt
Bmw 330i Oil Change
I have just bought a 2001 BMW 330i Sport E46 (120k miles)
Now I just just need to get the oil changed.
What grade is recommended for the 330i with this kind of mileage?
Opie Oils generator seems to suggest 0W30 or 5W40 Fully Synthetic and around 6.5 litres of it?
I have read a guide online how to change the Oil and it all seems fairly typical.
How does everyone get around the 36mm socket requirement for the oil filter, do I just buy one or can I use a wrench without issue?
Any guidance much appreciated.
36mm?? I swear my oil drain plug is a lot smaller than that!
Main dealers use 5w30 Castrol Edge.
At that mileage, you may wish to try the Opie recommended 5w40 as it will be a little thicker at operating temp, especially as we enter summer.
Use fully Syntheic and go with a decent product like Fuchs Titan or Silkolene Pro.
Sorry my bad, I didn't make it clear that I was talking about the oil filter cap :lol:
Don't apologise! It was Mit's misinterpretation and general grumpiness that he should apologise for :lol:
Thanks for the super friendly replies everyone.
I will pop to my local motorfactor after work tomorrow and pick up the bits. Sounds like 5W30 is the best choice, but 5W40 will sit equally happily.
Planning on swapping out the filter (presumably this should come with it's own seal) and oil sump washer.
I have a couple of other niggly problems to remedy, such as a slow drivers window and climate control panel only blowing hot but a quick bit of research shows this is probably the window runner cable and water heater valve respectively. So will try fixing these and post up my success (along with associated scrapes :lol: )
Thanks again :lol:
WTF?? I just misread it lol, my original response was just going to be "Get a socket" lol :lol:
Mobil1 0W/40 is a popular choice and IIRC what BMW now use.
My main dealer definitely does not use Mobil 1 - they only ever used Castrol Edge (as it suggests on the oil filler cap itself)!
Went to Sytner BMW a month back and the guy offered me Mobil 1 5w30..Use 0w40 in mine however..cold start protection and runs thicker when warm. Helped my car with its oil consumption! :(
Must change with dealers then, but I know mine does not use Mobil.
Like I said earlier - for higher mileage cars such as yours, 0 or 5w40 will be better for oil consumption and wear protection.
Oil Change...DONE! ;)
I spoke to Opie Oils for further clarification and as long as the oil is LL01 it will be fine, so any 0w XX or 5w XX, hence why people are probably seeing so much variation across the dealerships.
Also managed to sort out the heater valve by applying a slight tap of the hammer :P, obviously just a little jammed :D . Makes a nice change when things are simple!
