Jonny
Butterfly valve exhaust mod
Well, after reading this thread I thought I'd check to see if my valve actually moved, surprise surprise, it was stuck solid!
I gave it a few taps, and then a few harder taps and it was so jammed up that the butterfly actually bent backwards, leaving the left-hand side in place. I managed to solve this by smacking the join from the spindle to the valve until it actually came off, then I was able to extract it with some long-nosed pliers. Just thought I'd post this incase anyone else got stuck this way!
I tried this and I actually cannot get it off!! I went nuts with a rubber mallet and chisels and it will not budge from the spinel. Although the right side does bend backwards! Anyone have any tips?
Managed to do it, more brute force and ignorance was required!
Edited by ben m
Had a look under the rear of my 325ti at the weekend and could not find anything. It's soooo quiet! Hardly any decent back box's for the Compact (that aren't ££££) on the market!
With the engine off the valve will be open. Engine on = vacuum. Vacuum = shut. And vice versa.
The valve will then open at high revs, speed should have nothing to do with it.
Mine is currently shut with the engine off and cold. I take it this isn't right? If I poke my finger in and try to move it, it won't budge...
Also, I couldn't find the vacuum hose, unless I'm looking in the wrong place. Where abouts should I be looking in relation to the tail pipe?
Well I did some googling and saw some people had found theirs was siezed and took to it with a screwdriver/chisel and a hammer to free it... so I found the vacuum pipe, plugged it with a screw... then took to the flap and it was so bad that I managed to bend it to start with, and eventually, the whole thing just snapped off :lol:
No matter though as I'm happy with the sound now, and I was planning on getting an aftermarket exhaust fitted anyway... this may have saved me a few pennies for at least a little while :D
I'm sure the exhaust is new on my car as it's mint, the flap moved so easy - so plugged the pipe and it sounds better than before.
The pipe on the actuator can be tight but if you lightly grab it with some long nose pliers and turn side to side it comes off easy.
Just to say thank you for showing me this mod. I found my exhaust valve stuck shut, so I freed it up with WD40 and found the link arm had come loose from the valve lever. I replaced it and then plugged the vacuum hose. Sounds much better now!
Thanks Again
I too found mine stuck. The flap is now removed which I'm happy with but I was concerned at why it got stuck. Plainly it wasn't being operated hence it seized. So either the car hadn't been used in the upper rev range for ages or the valve wasn't being operated for other reasons. I eventually tracked down the hose from the back of the inlet manifold to the vacuum reservoir had perished. It hadn't split but was crumbling and leaking. Worth checking folks as it's a vacuum leak that affects engine operation.
My flap doesn't seem to close when the engine is running despite being able to freely push it closed. Maybe the pipe has a split or is perished... is that a concern?
The valve remains open when the car is at idle but as you pull off the valve closes to keep the sound level low. I believe it opens up again at around 3 or 3.5k revs.
Just done mine ..ended up removing it in the end it was stuck solid there was a hell of a lot of soot behind is pipe was blocked could have filled half a coke can ...defiantly sounds better at just under 2 k rpm
Hello I know this is an old post but I need help, my 330i auto is annoyingly loud and I just realised the valve i stuck open! I tried to close it but it's stuck and I don't want to push hard just in case I might break it, the owner before me was an old lady and I doubt she done what you did so my guess is that it's suck, should I spray WD40? Or what?
Thanks
Thanks
You can pull the right exhaust tip off which will give you better access, i would try penetrating fluid on it once removed. Mine was also seized but in the shut position.
