Devil2575 Posted August 7, 2010 Report Share Posted August 7, 2010 No pictures i'm afraid as i don't want to get my digital camera dirty but this is a very simply 10 minute job. 1. Lying on the ground slide under the back bumper of the car. You should be able to see each parking sensor including the wire connection. 2. There's a clip on the top side of the sensor that just needs pushing up away from the sensor. 3. With the clip pushed up push the sensor from the front and pull it fropm the back till it comes out. 4. Remove the wire/plug and fir the new sensor. 5. Push back into the bumper and make sure the clip is in place. the sensor can only be mounted on way so you can't really get it wrong. It takes about 10 minutes max. Link to comment Share on other sites More sharing options...
