daveyb
Tyre Size
Slightly confused by what your asking mate?
Do you mean what width of tyre? As in you've currently got 225s on. Dependant on the width of the wheel (8.5 at the rear?), that would be a 255 normally!
Thanks the wheels are 8.05/17.0 front et38 rear et47.
the tyres that are on at min are 225/45/17 and its more the rear tyres i want bigger sized..the wheels i took off had different sizes front and rear.but at the same time i dont want to have to roll archer out. hope you understand.cheers
You can fit up to 19" wheels on your car with an offset of up to 35 without having the arches rolled. You can fit wheels up to 9j wide on the rear without any issues.
As for tyre width. The best setup seems to be 225 on the front (any wider & the steering will feel heavy), and 255 on the back (you can fit up to 275 on 17" wheels as long as the wheels are wide enough). If you have 19" wheels don't go any wider than 235 on the rear or you will get rubbing.
Clear as mud :lol:
