323dtr Posted November 27, 2010 Report Share Posted November 27, 2010 If your brake wear light comes on and you replace your pads and the light stays on.Turn on your ignition lights on (do not start the car) count to 30 and the light will go out.If i comes back on then you will need to replace the sensor but 9 times out of 10 this does the trick. Alot of people change the sensors as a rule when doing pads but may still need to turn the light out i did lol. Link to comment Share on other sites More sharing options...
Daz 330 Cs Posted November 28, 2010 Report Share Posted November 28, 2010 The Pad wear sensor only need replacing if the dash light comes on. If you change the pads before they get that low then you can re-use . Simples Link to comment Share on other sites More sharing options...
Rob- Posted November 28, 2010 Report Share Posted November 28, 2010 I'd imagine as soon as you put your foot on the brake with the old sensor in the light will come back on. Edit, just thought about it and yes you're right lol Link to comment Share on other sites More sharing options...
