Nodderdog
Rear light cluster warning lights
Here you go!
It took me approx 15mins per side to do (and I was working slowly).. cool.gif
Good luck mate!
i have had an instance of pressing brake and upper rear tail light and lower rear tail light illuminate,to eventually fix it so i have some brake lights i removed the upper rear brake bulbs,i only now have lower brake lights but at least have each side equal,so am going to try your fix out,would my problem be the earth,great write up and solution by the way,ps all bulbs were working as i swapped and tried them
Edited by rasa
It's been 4 years since I posted that guide on the 1st page.. Finally had to do my own car last week! lol. All sorted now..
connor - what symptoms are you seeing?
I've been having an issue with the warning lamps on the dash coming on to tell me that I have a rear bulb blown on the off side and once last night on the nearside but I have no bulbs out. I thought it might be a bulb on the way out but then read this thread kindly linked by Bert recently.
So I went out to the car this afternoon and fixed it:
One melted plug from the offside
The connector that is all burnt up, which fell out of the plug
The earth wire simply cut and attached to the earth on the circuit board by way of crimp connectors as it was 'orribe out there so I didn't want to mess about with soldering.
I didn't muck about with splicing it into the wire from the plug and did it the same way as Bert as I couldn't see the point. You are just connecting it to the same part of the circuit board that the pin on the plug goes to anyway!
Now it's no good that BMW didn't use wire and a plug that is man enough for the job but at least they left that tab on the circuit board for a spade connector to push onto.
I have posted this in my own thread on the Photo Zone section also but I have posted in this section too as it is where people may look if they have a problem and it might help someone else out too.
Kirkynut
Hi
I hope someone can help me pls
My brake lights have stopped working . The bulbs are ok  and I have changed the brake pedal switch thinking it was that.  The fuse is ok. And as this post suggests checking the wires on the connector to the bulb , I have done so and none are burnt out .
Can some one please help I'm getting bald pulling my hair out
Thanks in advance
(Bmw 318, 1999, petrol)
