Darklordvader Posted September 16, 2011 Report Share Posted September 16, 2011 Rear parking sensors on the newly purchased 318i seem to be dead , I gather you select reverse and they beep when you get near anything ? right now there is nothing , can anyone point me in the right direction to sort it out please. Cheers Steve. Link to comment Share on other sites More sharing options...
CliffThomson Posted September 16, 2011 Report Share Posted September 16, 2011 Is there a loud beep that goes on for a while when you select reverse? Link to comment Share on other sites More sharing options...
Darklordvader Posted September 16, 2011 Author Report Share Posted September 16, 2011 No , nothing at all. Link to comment Share on other sites More sharing options...
CliffThomson Posted September 16, 2011 Report Share Posted September 16, 2011 Start with the fuse, you should get something. Listen to each sensor with the car in reverse, and you should hear a ticking noise. If no ticking = knackered sensor. If none are ticking, i'd start looking at cables and connections Link to comment Share on other sites More sharing options...
Darklordvader Posted September 16, 2011 Author Report Share Posted September 16, 2011 Thanks Cliff , great help , any idea what fuse number would be , as I have no handbook with car.............you wouldnt no where I could find a handbook would you? Cheers Steve. Link to comment Share on other sites More sharing options...
CliffThomson Posted September 16, 2011 Report Share Posted September 16, 2011 I'll find out when i get home and let you know. Link to comment Share on other sites More sharing options...
Rob- Posted September 16, 2011 Report Share Posted September 16, 2011 (edited) Thanks Cliff , great help , any idea what fuse number would be , as I have no handbook with car.............you wouldnt no where I could find a handbook would you? Cheers Steve. There should be a few PDFs on the net for the handbook. Assuming you mean the owners manual? To find the right fuse just drop your fusebox down and there should be a fuse diagram with the functions, position and amp rating of each fuse. If it's not there then google image search should bring one up. Edited September 16, 2011 by ROB1986 Link to comment Share on other sites More sharing options...
Darklordvader Posted September 16, 2011 Author Report Share Posted September 16, 2011 Thanks Rob1986, Owners Manual thats it , just could not think of the name , old age for ya! Cheers Steve. Link to comment Share on other sites More sharing options...
Darklordvader Posted September 17, 2011 Author Report Share Posted September 17, 2011 Hi All , Check the rear parking sensors this morning and they are all clicking/buzzing so they must be ok , where would bm put the beeper in the car somewhere at the back Iam thinking would I be right or wrong ,can anyone confirm where to look please. Cheers Steve. Link to comment Share on other sites More sharing options...
RickyZ Posted September 19, 2011 Report Share Posted September 19, 2011 Hi All , Check the rear parking sensors this morning and they are all clicking/buzzing so they must be ok , where would bm put the beeper in the car somewhere at the back Iam thinking would I be right or wrong ,can anyone confirm where to look please. Cheers Steve. IIRC its under the dash in the drivers footwell, if u lay in the drivers footwell and face up its on the bottom/underside of the dash. Link to comment Share on other sites More sharing options...
CliffThomson Posted September 19, 2011 Report Share Posted September 19, 2011 Beeper is under the trim panel next to the steering wheel. If you look for the final stage resistor replacement instructions, you'll find it easily. Put the lights on, take the key out and open the door and see if you get anything, i think it's the same beeper that services both. If that works, you may have one of the connections to it bad or unplugged. C. Link to comment Share on other sites More sharing options...
Darklordvader Posted September 19, 2011 Author Report Share Posted September 19, 2011 Superb info guys will look into it as soon as..... Cheers Steve. Link to comment Share on other sites More sharing options...
Guest b33mer320t Posted September 21, 2011 Report Share Posted September 21, 2011 Rear parking sensors on the newly purchased 318i seem to be dead , I gather you select reverse and they beep when you get near anything ? right now there is nothing , can anyone point me in the right direction to sort it out please. Cheers Steve. hi again. switch on your ignition,but dont start her up. select reverse gear and go to the rear of your car and put your ear to all your sensors one at a time and you will hear a ticking/buzzing sound. the one(s) u dont hear are the faulty one(s) and thats the one u need replacing. you should be hearing a continious beep at the moment when you start her up which is a warning your pdc has a fault. Link to comment Share on other sites More sharing options...
Darklordvader Posted September 22, 2011 Author Report Share Posted September 22, 2011 hi again. switch on your ignition,but dont start her up. select reverse gear and go to the rear of your car and put your ear to all your sensors one at a time and you will hear a ticking/buzzing sound. the one(s) u dont hear are the faulty one(s) and thats the one u need replacing. you should be hearing a continious beep at the moment when you start her up which is a warning your pdc has a fault. Hi There is no beeping what so ever and I have done the ear test and they are all ticking/buzzing so this weekend I will try to find where the beeper is as it must be this which is at fault or the the wiring.... Link to comment Share on other sites More sharing options...
RickyZ Posted September 22, 2011 Report Share Posted September 22, 2011 Hi There is no beeping what so ever and I have done the ear test and they are all ticking/buzzing so this weekend I will try to find where the beeper is as it must be this which is at fault or the the wiring.... The beeper location is described in posts further up ^^^ Link to comment Share on other sites More sharing options...
Darklordvader Posted September 22, 2011 Author Report Share Posted September 22, 2011 Yes you are right , Iam sitting here feeling like s**t , another cold from the kids , just could not be bothered to go into to much detail....... Link to comment Share on other sites More sharing options...
RickyZ Posted September 22, 2011 Report Share Posted September 22, 2011 Yes you are right , Iam sitting here feeling like s**t , another cold from the kids , just could not be bothered to go into to much detail....... ah ok, sorry to hear that dude, hope ya feel better soon Link to comment Share on other sites More sharing options...
Darklordvader Posted September 23, 2011 Author Report Share Posted September 23, 2011 Beeper is under the trim panel next to the steering wheel. If you look for the final stage resistor replacement instructions, you'll find it easily. Put the lights on, take the key out and open the door and see if you get anything, i think it's the same beeper that services both. If that works, you may have one of the connections to it bad or unplugged. C. Have done the test you suggested with the lights and the beeper works so I think I may have to start pulling the car apart to look for a bad connection..... Link to comment Share on other sites More sharing options...
CliffThomson Posted September 23, 2011 Report Share Posted September 23, 2011 It's unlikely the beeper will have failed, i suspect that if your PDC Sensors are ticking, and you're not getting the long beep when you put it in reverse with the ignition on, then the connection to the beeper is unplugged, or you have a wiring issue somewhere. The beeper is on the panel thats directly next and to to the left of the little cubbyhole in the dash next to your right knee when you're sitting in the car. There are 3 or 4 connections to it, for PDC/lights etc. If you're really stuck and can't fix it, and don't mind a trip round the M25, let me know and i'll be happy to take a look at it for you. Regards, C. Link to comment Share on other sites More sharing options...
Darklordvader Posted September 23, 2011 Author Report Share Posted September 23, 2011 Thats damn good of you sir! I will give it my best shot and see what happens ,not sure when cos its my 29th wedding anni this weekend and if I have my head buried in a car I think I will be wearing my nuts as earings!! Cheers Steve. Link to comment Share on other sites More sharing options...
Aidoe46 Posted September 12, 2012 Report Share Posted September 12, 2012 was this issue sorted as im having a problem with my speaker tone beeper aswell, can't figure it out,all rear PDC's are clicking Link to comment Share on other sites More sharing options...
NervySi Posted September 17, 2012 Report Share Posted September 17, 2012 Yeah, my PDCs are not all tickety-boo either. I dropped the car off, with a replacement sensor, at my local garage last week and though the new sensor plugged straight in, the system was still failing (and giving the 3-second 'beeeeeep') each time the ignition was switched on. It would behave after being reset on the diagnostic computer, then fail again. Mechanic reckons the control unit has had the d**k, but managed to switch off the long warning beep which was actually more annoying than having no PDC :-) Anybody here successfully replaced the PDC control unit? Are there different versions, as with the sensors? Link to comment Share on other sites More sharing options...
Lee lad Posted October 11, 2017 Report Share Posted October 11, 2017 Right so I've had the intermittent 5sec tone, reversing sensors not worked the hole time I've had the car, not reading up on how too check for clicks till today I purchased 4 budget brand new sensors off eBay, installed and no joy, but all four was clicking away as they should, thinking one of them must of been defective I move on too check the old ones and 3 was working bar one, put the three working ones back in and as I unplugged the fourth the 5 seconds tone kicked in, re-plugged back in and the sensors started working, but after switching off the ignition, stopped working, repeated unplugging the fourth brand new replacement and plugged back in and all was well again till I switched off the ignition , so it seems my 325ci don't like the cheap replacements and will source a second hand original , so peeps with working clicks, one or all could be cheap replacements your car don't like, hope this helps. Link to comment Share on other sites More sharing options...
succentor Posted August 17, 2019 Report Share Posted August 17, 2019 Lee lad, Did you ever get this sorted? I’ve had the exact same problem, one sensor clearly faulty, replaced it with a cheap non-BMW part and while I can hear the sensor clicking, it clicks unevenly and it does exactly the same as yours, works OK when first plugged in but after turning ignition off and back on it doesn’t work at all (not even a long beep). 2003 320CI convertible Link to comment Share on other sites More sharing options...
momo Posted August 17, 2019 Report Share Posted August 17, 2019 9 hours ago, succentor said: Lee lad, Did you ever get this sorted? I’ve had the exact same problem, one sensor clearly faulty, replaced it with a cheap non-BMW part and while I can hear the sensor clicking, it clicks unevenly and it does exactly the same as yours, works OK when first plugged in but after turning ignition off and back on it doesn’t work at all (not even a long beep). 2003 320CI convertible Replace with genuine.. Link to comment Share on other sites More sharing options...
