Johnny 5C
Obc Stalk Retrofit Coding.
Anyone in Portsmouth/Fareham/Southampton area who can do the coding to get the OBC stalk working?
Im thinking about replacing my poverty spec stalk with an OBC one. It looks like a fairly simple job to retrofit the hardware, I just will then require the coding done.
Cheers
John
Edited by Johnny 5C
Jonny are you aware that cruise control on our 1.9's are mechanical? There is a box on the near side front suspension turret that has a cable running to the throttle body
Im confused :D cruise control???
I want to order PA soft now! :lol:
Those that have both PA soft and NCS, is there much you can do in either one that the other can't? Or is it mainly the interface that makes PA better?
Edited by Gaz
Gaz, PA soft can reprogram used parts with your VIN...great for clusters and ECUs and stuff...dont think others can do that! Also mileage correction.
Edited by mintimperial
If anyone can post up how to do it, then i am more than willing. As have all programs now pretty much, bar NCS
If no one does post up, then i will have a google and see :)
Edited by chris
