carldamo Posted October 13, 2012 Report Share Posted October 13, 2012 It's position 2 m8. Once you've done the 10secs on then 10secs off...half way through way you will hear a click under the handbrake area. position 1 worked for me, before I did it I really need to give it some when reversing etc so it didn't stall, after the position 1 reset its fine, maybe its position 1 or 2 ?? as I did position 2 as well but no difference to the improvement I experienced from position 1... Link to comment Share on other sites More sharing options...
zimzimmer46 Posted October 13, 2012 Report Share Posted October 13, 2012 Ur car is back to front then lol Link to comment Share on other sites More sharing options...
carldamo Posted October 14, 2012 Report Share Posted October 14, 2012 maybe its my driving and all in the mind... just got used to the biting point and stopped stalling lol Link to comment Share on other sites More sharing options...
daz031178 Posted December 31, 2012 Report Share Posted December 31, 2012 Didnt bloody work for me Link to comment Share on other sites More sharing options...
Larry D Posted December 31, 2012 Report Share Posted December 31, 2012 If you have a cable driven throttle you can get the same sort of effect by disconnecting the battery for about 30 minutes, you m54 guys could use that way to. Wire a battery cut off switch into your dash or phone tray, then simply flick it off when you park, back on to start the car next time, instant reset. Link to comment Share on other sites More sharing options...
mrsahota Posted January 1, 2013 Report Share Posted January 1, 2013 great tip!! Link to comment Share on other sites More sharing options...
dirtydieseldog Posted January 2, 2013 Report Share Posted January 2, 2013 Tried position 1 didnt notice anything, gonna do position 2 now before i set off to work. Update to follow. Link to comment Share on other sites More sharing options...
dirtydieseldog Posted January 2, 2013 Report Share Posted January 2, 2013 Pos 2 tried, still no difference Link to comment Share on other sites More sharing options...
steuk Posted January 31, 2013 Report Share Posted January 31, 2013 Excellent. Just done mine and it worked a treat. Thanks for the tip Link to comment Share on other sites More sharing options...
Ryan330c Posted March 21, 2013 Report Share Posted March 21, 2013 Off out now, gonna try this. 10 secs on P1 10 secs P0 then Start engine as normal wish me luck Chimp Choker 1 Link to comment Share on other sites More sharing options...
Knuckle Posted June 15, 2013 Report Share Posted June 15, 2013 Can someone please clarify if "decent 1" is basically one click forward, or does it mean as far as it goes without turning the engine , I.e ignition on. Did it a minute ago as mean seems laggy and think it made a slight difference but not sure if I did it roght Link to comment Share on other sites More sharing options...
ravalaarrr Posted November 23, 2013 Report Share Posted November 23, 2013 Going to give this ago this morning. Judging by the response a decent little bit of info.. Cheers Link to comment Share on other sites More sharing options...
330cian Posted April 18, 2014 Report Share Posted April 18, 2014 I just tried this, and there's a definite improvement in throttle response and therefore power availability in gears 1 and 2 from launch and out of corners/roundabouts etc. The engine seems to be getting through the rev range to the red line quicker, so I need to watch out for that! Link to comment Share on other sites More sharing options...
Testaculese Posted July 28, 2014 Report Share Posted July 28, 2014 Tried this, thought i'd share my results. My car is a pre-facelift 2001 325 auto. Just recently got it so no idea what previous driver was like. Tried the re-set procedure using position 2 on the ignition barrell. I heard an audible but faint click (like a relay) from the glovebox area after about the right amount of time. As for the result, i'm pretty sure the previous owner must have wafted to the shops and back all day as the difference was dramatic! First pull away from a junction the thing took off like a stabbed rat! Even the DSC stepped in. I have found after a week of driving sedately to work and back the box and 'learned' and reverted back to 'lazy old man mode' So from now on i'll either reset it every week or just drive it to work li I stole it SlamE46, Chimp Choker and TOOM 3 Link to comment Share on other sites More sharing options...
Zonda_ Posted September 4, 2014 Report Share Posted September 4, 2014 Just reset mine using the pedal to the floor with key in position 2 and it's made a big difference. My car had developed a surging throttle and would even kangaroo like a learner. All gone now. Link to comment Share on other sites More sharing options...
Dan ATR Posted October 13, 2014 Report Share Posted October 13, 2014 I tried this and it works a treat. Link to comment Share on other sites More sharing options...
The_Judge_ Posted November 19, 2014 Report Share Posted November 19, 2014 I do mine in INPA every 3 month or so. E46 Convertible Imola Red Chimp - How do you do it on INPA ? Link to comment Share on other sites More sharing options...
Chimp Choker Posted November 19, 2014 Report Share Posted November 19, 2014 From memory mate. Fire up inpa Select e46 Engine, then select engine type m54 etc. F4 or error F7 or adaption I normally clear all. Don't have engine running though or it'll go into limp mode and the dash lights up like Blackpool at Christmas. Enjoy The_Judge_ 1 Link to comment Share on other sites More sharing options...
marc l Posted November 19, 2014 Report Share Posted November 19, 2014 Would this work on my 2001 318? It's got a throttle cable not the fly by wire type Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jay. Posted November 19, 2014 Report Share Posted November 19, 2014 Would this work on my 2001 318? It's got a throttle cable not the fly by wire type Sent from my iPhone using Tapatalk No mate, just the later fly by wires Link to comment Share on other sites More sharing options...
B0B Posted November 19, 2014 Report Share Posted November 19, 2014 Would this work on my 2001 318? It's got a throttle cable not the fly by wire type Sent from my iPhone using Tapatalk No it only works on the fly by wire ones Link to comment Share on other sites More sharing options...
marc l Posted November 19, 2014 Report Share Posted November 19, 2014 Thought so! Cheers lads Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
WhackyWill Posted December 11, 2014 Report Share Posted December 11, 2014 Did mine today, maybe I need to go on a run to notice any difference. Hope it will increse my fuel consumption a bit. Link to comment Share on other sites More sharing options...
Chimp Choker Posted December 14, 2014 Report Share Posted December 14, 2014 Nice post, however nyet Link to comment Share on other sites More sharing options...
The_Judge_ Posted December 14, 2014 Report Share Posted December 14, 2014 Report button peeps, thats what its there for .... WhackyWill 1 Link to comment Share on other sites More sharing options...
