Jamie330d Posted March 22, 2013 Report Share Posted March 22, 2013 I asked a while back about what I needed to convert my 330d estate from a 5 speed to a 6 speed, this is how done so advice for anyone thinking about it, it's NOT worth it lol! To make it work you need: 6 speed gear selector 6 speed clutch 6 speed gearbox 6 speed propshaft Wire Gearbox mount Essentially it's a straight forward job, just swap the box ect you will need to change the clutch as its got twice the amount of splines on the first motion shaft, the dual mass is the same, you will also need to cut the reverse light sensor wire and extend it as the 6 speed one is further back, the gearbox mount for under the floor is also different from the 5 speed one so this needs to be changed aswel, also cruise control doesn't work in 6th. Hope this helps anybody going to attempt conversion Blair and momo 2 Link to comment Share on other sites More sharing options...
L333JSA Posted March 22, 2013 Report Share Posted March 22, 2013 What was you hoping to gain from this conversion ? ...an extra gear perhaps? Blair, Aidan316i, nomis and 4 others 7 Link to comment Share on other sites More sharing options...
L333JSA Posted March 22, 2013 Report Share Posted March 22, 2013 ...and to show off that his 5 speed knob can actually go that extra gear!! Lee131, Rich_D and Mengwalton 3 Link to comment Share on other sites More sharing options...
