blynham
GM5 Module help
After searching on here, i'm pretty sure my GM5 module has gone.
The drivers door will only unlock when you insert the key but will lock when you press the button.
Seen some on ebay for about £30 so are these an easy fix? Would i be good to go if i swapped them or would the new one need to be coded to the car?
Help is greatly appreciated
Cheers, Brad :thumbsup:
You can get a replacement key from BMkeys do a search on here for the thread you can get a oe type key or a bentley flip style
key. As chimp said try your microswitch first :thumbsup:
I had a similar problem when I first got my car,apparently my relays had gone in the gm5 module,got them replaced while I waited for £50,I put his number and address on here some where,he's based in Harrogate, but like chimp choker said been known on here for the microswitches.
Those benltey keys look damn nice lol. A bit of a treck for me to get it coded though. Don't dare to go my BMW dealer, even with trade discount I can imagine the price would be ridiculous.
Sent from my iPad using Tapatalk
I think its 115 to 120 from bmw depending on the dealer. Bm keys you can send off your ecu key box and they can code a new key that way but you will be without a car till it comes back?
If I ordered a Bentley key from them could I get it coded at my local BMW? Can't be without a car for even a day lol
Do all the doors (including fuel filler cap) unlock/lock when you use the key in the door? if they do then the GM5 is ok and it will be the key or FZV module
No only the drivers door unlocks when i use the key. Guess its the GM5 then
Does sound like the relays inside the GM5 have failed, you can get it repaired easily enough. There are a few people out there offering the service, one quick example http://www.ebay.co.uk/itm/Repair-Service-BMW-GM5-Central-Locking-Relay-Fault-3-Series-M3-Z8-X3-Z4-E46-/271515944101?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f379c84a5 In my opinion getting your original repaired is easier than a replacement module which will then need coding to the car.
With the module removed you can still drive the car but you wont have any central locking or windscreen wipers.
HTH
Charlie
