reaudioxxx
e46 engine making noise
car was running great and now all of a sudden at low revs car makes a noise up until 3krmp, cant explain the noise but its like a grind/whistle noise. car doesn't smoke or feel like it is loosing power either any ideas what it could be?
Is it grind, whistle or both at once? A video with the symptoms would help.
more of a grind the video wont pick up the noise will try again today, its coming from the front of the engine, i know for sure its not the belt or the pulleys as these have just been replaced
The parts that have just been replaced are the first things i'd be looking at if the noise has
started since they were fitted.
Take the aux belt off and run the engine for a short time to rule out the pulleys etc
Edited by dunk1
The parts that have just been replaced are the first things i'd be looking if the noise has
thanks will have a proper look over the weekend and see if i can find anything
