TamHam79
E46 330i fault code 5e1a , f4, 53
Got code p335 long cranking , no power ,dsc and orange brake lights on dash so replaced crankshaft sensor and got it plugged in from a friend and got
He reset and they came back on  straight away he's stumped so am I where do I go from here , before the lights came on and the long cranking when driving the car it chugged and the dsc and brake came on loss of power and long cranking after that any help much appreciated
On 09/06/2016 at 06:38, Ragamuffin said:
You say you have replaced the crank sensor, but sometimes you need to get the ECU reset afterwards, or your car will go into limp mode. A good indie with all the relevant software should be able to help you out.
I have had it ecu reset but codes came back straight away still at a loss doing ma head in now
