Dicky
Sticky Exterior Door Handle Fix
It seems that this video is a bit miss leading, in dealership we used to slacken off the bolt lift the handle to approx half free play and tighten the bolt at the same time, also worth mentioning the bolt has a left hand thread which I think explains a few peoples problems. Once adjusted the mechanism needs lubricating some sort of spray grease is best (do it with window up) use a can with a long tube and spray though the access holes and down the side of the outer handle in the upward position.
Hope this helps.
echo the above s spender is 100% right,the bolt needs to be slackened off first before you tighten it up, otherwise you run the risk of stretching the bolt and damage to the threads or worse
Damn I was hoping that this would work on my drivers side!
I recall many years back on my 330ci I had the same issue and the doorcard had to come off and there was a simple fix of cable tieing 'something' together to that there wasn't as much slack in the mechanism - any ideas? My memory is rubbish and can't for the life of me remember what the fix was!
sorry for the donse question guys, when you say sticking, do you mean it pulls out half way, and then needs another good tug to actually oppperat the latch??this is what both of mine are like, i tried just tightenng this the other day, didnt really have much effect if im honest....any more suggestions guys...
Thats my understanding of it too, and my driver side is like this.
I tried it and didn't do anything, I tried the window down method and sprayed some WD40 down there for good measures and lasted all of 2 days and now its sticking again!
Anyone have any other ideas? other than taking the doorcard off and investigating?
Tried this on the weekend, seems i should have read it properly - Mine wouldnt tighten anymore, well, a very small amount.
So reading the different methods, it seems to work by loosening first, then re tightening it again? I remember on my last one i stripped the thread and it went back on itself lol. Dont need to mess about with the handle?
