Keith
Guide To Replacing Your Front Control Arm Rear Bushes
I've had my Powerflex bushes on for around 10k (1 year) and they still feel good! Deffo makes it feel tighter :)
I watched the mechanic try and get the old bushes out and it was a right PITA! so i'd happily pay someone else to do it for me.
Haha.... ;) Dirty mind.
Thanks for the feedback though, I think ill get a set - If i get them pre-mounted like this then it will save on time/labour anyway. Where did you get them from and what sort of price?
If you got them pre- mounted like that it would make an easy peasy DIY!! Getting them off and on its the easy bit, it's just removing the damn old bushes from the lollipops! (i know what your thinking) :P
Probably won't even take an hour to do that way!
Edited by MARSBUDE
I dont have the time/effort to do it myself, last time I jacked my car up on the drive the jack started sinking haha OOOPS! Garage is the way for me... plus its nice seeing the entire bottom of your car from time to time to have a good old nosey!
BOLLOX is it easy to get them off the wishbone!
I got the puller from machine mart that cost £16ish although you "might" get away with the smaller £10 one.
Tip I found was to put a socket between the point of the puller and the wishbone as the puller point tends to slip off the wishbone and hit the rubber of the bushes.
It took me many goes though, the puller would slip off from time to time just when you think you've got it. I got quite angry quite often too. At one point hitting the road with my rubber mallet and shouting the C word.
I also strained my neck.
Annoyingly, it felt good for a few days (did it last Satuday) and then it started making a rattling noise when going over bumpy surfaces. So now I'm gonna have to jack it all back up and have a look and tighten things up.
the puller point tends to slip off the wishbone and hit the rubber of the bushes. It took me many goes though, the puller would slip off from time to time just when you think you've got it. I got quite angry quite often too. At one point hitting the road with my rubber mallet and shouting the C word.
Sounds WELL EASY haaaaaaaaaaaaaaaa! I think ill stick to getting my local mechanic to do it.
Did this today, so glad I've joined this forum, I think I'd have really struggled without the advice on here. Anyway, popped down to Halfords to get a puller (£26) and the old bushes came off in literally 2 minutes per side. Saying that though, I reckon my 3 year old nephew could have pulled the drivers side one off with his bare hands......it was a little...."worn" (see below, this is how it came off)
Getting the old bushes out of the lollipops
Put the purple center bits on the arms and left the rest for tomorrow as it's bloody baltic outside! The ground in the second pic is actually frozen solid!
I have got a spare pair of 'lollipops' available if anyone would like them to fit Powerflex bushes into.
How much do you want for them plus postage? Are they the 66mm?
Edited by twist944
Needless to say, check which way they go in before doing so... I dread to think of the mission involved to remove one once it's in.
I can say from personal experience, that if you fit a bush the wrong way, it WILL NOT be coming back out unless you have access to a 7 tonne press :lol:
Also, replace the bolts. THeyre stretchers. My BM mate said he's never replaced the bolts, but then you hear about guys having sheared bolts, so for the sake of it, Ill be replacing mine when I do them.
I've just being told by Kwik Fit these need doing.
Will these fail my MOT next month, if left?
Also, does £170 for both sides (parts and labour) sound right? If I was to take it to a garage.
I'm trying to weigh up, if I should pay them or just follow this guide. I don't wanna f**k anything up. :lol:
Sounds expensive! Powerflex bushes are £49, and its about an hour to fit.
