Paul TVR
Chinese headunit amp problem
I'm having an issue with the stereo installed in my e46, it was fitted by the previous owner, it's a windows ce (I think) has been working fine,  except poor radio reception,  but after a long drive the nearside front channel started making a loud high pitch noise,  now the channel seems OK when first driving but drops out after a few minutes. Guessing the amp is blown.
Is this a common issue with them?
Have you checked that there is power to it?
I only say this as I had same problem with bad radio reception, mine had a wire going to it but no power, found that you needed to connect the blue amp out wire to it to give it power.
