Megadodo
ABS unit swap coding issues
I have an E46 318Ci with me at the moment and its had a 325Ci engine dropped into it. Its got an ABS warning light up that is due to an identification mismatch error. I've not had this before despite swapping several ABS modules in the past? Is this due to the fact that the chassis, engine ECU and ABS module numbers are all from different vehicles and can it be coded out? If so, how does that happen?
