creo Posted September 9, 2020 Report Share Posted September 9, 2020 Hello, so I purchased an xtrons unit for my e46 harmon kardon system with sat nav etc. As an audio noob I'm completely lost with the audio connects, could anyone give me a hand? I bought the 6m cable extension loom as I understand I need this to utilise the HK system. This is whats in my boot: This is the connector going into the radio: This is the radio connector on the unit itself: Link to comment Share on other sites More sharing options...
creo Posted September 9, 2020 Author Report Share Posted September 9, 2020 This harness side 1: This is the other side of the 6m harness: Link to comment Share on other sites More sharing options...
creo Posted September 9, 2020 Author Report Share Posted September 9, 2020 This is the connections I have behind the front dash: Link to comment Share on other sites More sharing options...
creo Posted September 9, 2020 Author Report Share Posted September 9, 2020 These are the audio connectors coming off the xtron unit: 1: 2: Link to comment Share on other sites More sharing options...
creo Posted September 10, 2020 Author Report Share Posted September 10, 2020 Figured it out, I'll post details later. Link to comment Share on other sites More sharing options...
creo Posted September 10, 2020 Author Report Share Posted September 10, 2020 So, for my install you need: 6m aerial extension cable 6m harness Xtrons unit and cables 1) Back of the unit you can't go wrong, each plug will only fit into one socket. 2) You will get two bundles of connectors for which there is only one slot on the back of the unit. Use the one that doesn't have round plugs 3) Take the singular side of the 6m extension cable and connect it to the above 4) Take your BM Radio in the boot and disconnect the large connector Should end up looking like this, ignore the yellow/green wires (This is an aux I had put into the stock unit). 5) Plug will look like this, remove plugs 1 and 2 from the back of the connector 6) Take the other side of the 6m harness (with multiple plugs). Take the connector I've marked 3 and plug it into the back of the radio unit you just removed the stock connector from 7) Take the connectors I marked 1 and 2 and plug them into the back of connector 3 you just plugged into the stock radio😎 Take connector 4 from above and connect it to the stock connector in step 5, the blue bits do not block the connection. I thought they did which is where my confusion came from. 9) Unplug the aerial from the radio unit, it's marked in step 4. Plug the 6m aerial extension into the wire you just removed (nothing plugs back into the radio). Done Link to comment Share on other sites More sharing options...
