wilko
Oil Light
Quick question for 330 owners - does your oil light show yellow briefly when you first start the car? Mine does, so I topped up the oil (with Castrol Edge 0w40) last night, but it came on yellow for about 10 seconds this morning when I started it from cold - is this normal?
It should go off when you start the car. If it stays on for a bit, your oil level sensor is faulty. About £90 plus an oil change to replace.
Mine doesn't come on at all mate doesn't sound right really
could the sensor be cleaned or anything
I can't remember specifically if the light always comes on when you turn on the electrics or if it's just when the oil is low (or sensor faulty) so might just be that your car doesn't lose any oil so the light never comes on?
Mine had an inspection 1 less than 2 months ago and im certain it comes on when i start the car, as do all the other lights but for a period no longer than a few seconds then they all go off (except for the damn washer fluid which is on 24/7 due to a leaking HL Washer).
When you turn the key, the oil light should light up with the others, but red. This is an oil pressure warning light. When you start the car, the oil pressure builds and the light goes out.
The same light comes on when the oil level is low, but glows orange, not red. If it is coming on at all, the sensor is duff. The sensor is on the base of the sump, held on by 3 nuts with a built-in 'O' ring to stop leaks. They are notorious for failing - I've changed 3 now, and the one I fitted two weeks ago (2 weeks ago!), supposedly an original part, has just failed. It seems they fail two ways - coming on at start up, and staying on for 15-20 seconds, or coming on when the engine's warm and staying on until the ignition is switched off again.
They're a b***dy pain, and another very good reason for not buying an E90 - where I believe there is no dipstick, you have to rely on the warning light. Brilliant.
if it flickers red at any stage its oil pressure, yellow flicker is oil level, if its the pressure sender then it will need replacing i wouldnt drive it just incase the sender is working and you have no pressure then its bye bye engine
When I turn they key mine comes on and stays on for about a second once I turn it over. Nothing to worry about as far as I'm concerned. If it stayed on for any longer than that I'd worry. Plus I know that my oil level is exactly where it should be.
If its a genuine BMW part purchased from a dealer an its failed after 2 weeks they will replace it free of charge I believe. Cant remember if its a year or 2 year warranty they have but its deffo longer than 2 weeks!
I've already been back, and they've 'reset' it - OK at the moment, but if it comes on again they will replace it. Interesting, though - the old switch had the 'BMW' logo cast into the base. The replacement hasn't - but it still cost around £90 and was supplied as a genuine part.
Whoops, I actually paid attention to it today, turns out it's the EML and engine block (emissions?) lights that come on then go out. Please don't tell me thats even worse? lol.
When i replaced mine i remember reading on an ebay site, that the light come on briefly when you start the car, then goes off. But my genuine one definitely does not come on when i start the car, just when the oil is low.
Dont get anything other than genuine when it come to sensors :thumbsup:
Maybe have a look at your manual ;)
http://www.linquist.net/motorsports/bmw/3manuals
Engine oil pressure
Stop the vehicle immediately
and switch off the engine.
Check the engine oil and top off as
required. If the oil level is correct,
please contact the nearest BMW
center.
Engine oil level
Lights up while driving:
The oil level is at the absolute
minimum; therefore, add engine oil as
soon as possible. Do not drive more
than 30 miles (50 km) until you do.
For additional information, refer to
page 135.
Engine oil level
Comes on after the engine has
been shut off: add more engine
oil the next time you stop for gas.
page 135.
Mine does exactly the same it comes on for around 10-20 secs then turns off every time I start the car did you find out what it was and how to fix it if so please message me on how to sort it
Did you read the thread?
The oil level sensor is faulty when you start the car and the yellow oil can stays lit for approx 10 seconds.If you have this symptom then get the sensor replaced.
The best time to replace it is when your car is due a oil change as you have to drain the oil to replace this part,its located at the bottom of the sump.I bought my sensor off ebay but i bought the rubber gasket from main dealer
as i didnt like the look of the supplied gasket(it was green as opposed to the main dealer red gasket)Some people say the ebay ones leak through the plug connection but i have mine installed a long time and im happy
with it.
Edited by edber
i just replaced my sensor about 2 hrs ago with a brand new one, got it on ebay, its a erste wahle and has a 1yr warranty, I know the sensors are notorious for failing but come on, i took the car for a drive not even 10 mins and the yellow oil light came on and stays on, when i got the car the oil light would come on for 10-15 seconds on startup and go away, that was an OEM original part, then about a year ago i replaced the sensor with an aftermarket one and it put the yellow oil light on, and it was only installed in the car for a week tops, it would put the oil light on continuosly until the engine was stopped and it would stay on for a few seconds after the ignition was off or if i put the key to ignition position again, this new sensor i fitted today is doing the same thing, anything else it could be, i mean a brand new sensor already
i wonder what fooked it up. its only in the with new oil too :-( fook sake, ill have to get onto the seller too, its weird that it exhibits the same pattern as the one i removed, engine warms up, 15 mins of driving light comes on and stays on, will inpa show anything up? could there be a blockage etc?
I put 5l in my car, i know it takes 5.5l but its not the min tho, still ill top it up, but more than likely ill be draining it out again, sad lol
Edited by cf_corp
