individual
De Flapped The 320d Differently
Hi All.
I am new to the BMW seen. Is there an easy way to find out if the blanks have been fitted? Also if not what size would I need for a 06 320cd coupe. Are they easy to fit?
Many thanks
Steve
Hi Steve, welcome buddy! The only way is to remove the engine cover to expose the manifold and Im not sure at certain angles whether you can see the glint of shiny aluminum on the bottom of the manifold. If you want, you are best removing it completely. If you fit the blanks you get rid of the flaps, the actuator and the rods.
Hi All.
Many thanks
Steve
Thanks for the reply fella. Will have to have a look. Is there any way to know what size blanks I will need if it needs doing?
Thanks
Steve
Hi All.
Many thanks
Steve
Thanks
Steve
Trial and error. I bought two sets from PMW - one set of larger and one set of smaller, and just sent back the set which didn't fit once I'd done the job.
Would anyone know what sizes blanks were fit to which model year etc ? also if removing the actuator will it bring up fault code ? think I've seen else where that by just removing the rod at time of blanking off will be just fine ?
Also, where can i get a remap in west mids/ staffs area or is there a mobile that will come to you ?
Edited by steviep351
Keep the actuator in place, remove the rod. Just remove the flaps and install blanks. The E46 genuinely could have either size flaps, so order both sizes and send back the ones you don't need.
Edited by dontpannic
