theraven
petrol consumption
When the obc is set to the mpg readng, simply hold in the button on the indicator
stalk and it will reset the reading and you'll see _ _ . _ on the display for a second.
hi don
thx mate tryed that but get between 12 and 17 but never stays on certain figure?
and noticed that petrol light comes on half between first qu mark?? nowhere near empty
raven
its an average, so for the first few miles its going to yoyo alot. or does it keep changing after hundreds?
Sure its not on current MPG?
hi
it changes all the time theres no smoke etc seems to run nice
i,ve reset a few times but no joy also the mpg oon the dash (needle)
goes from 1 side to the othernever stabilzed
raven
My 323 manual is always averaging around 31-32mpg, with climate control on I get more when I go on a run, and I dont drive like a granddad either. Mine has been re-mapped though which improves fuel consumption.
It will change when your driving. What does it read once you've stopped?
I always re-set mine when I fill up. Although on my obc of the clubsport I can run current mpg and overall mpg readings so I have one for the current tank and one in my lifetime with the car.
I guess a lot will depend on auto v manual and what type of driving you do too. My wife's 318i only beat mine by .5 mpg if you compare the last tankful of each car!
The swingmeter/econometer is a pretty useless feature IMHO - it just relates to how hard your pressing the loud pedal!
The only true way of knowing your mpg is a brim-to-brim test.
I got a 318 steptronic auto, mine does about 24 - 25 mpg inside London city. . Reading that a 323 does 31 MPG, I should be doing more. . Having said that i can't remember what MPG I do on a motorway. .
Raven, the otherway to do a sense check of your MPG is fill up about 30 liters (that's 6 Gallons), re-set your meter. .
Check how many miles you do with 30L gas, divide by 6 which will give you MPG, if the answer is way out compared to the meter, then you got a faulty meter. .
we averages 31.3mpg on our 323Ci. This was all sorts of driving. It was also reset on a trip to south of france and back, and it was 31.7mpg when we got back.
hi lads
my petrol gauge seems to go down quick
are all bm,s like this as put a pony in sunday(25) clocked up about 70 miles
now its not far the light coming on (it conmes on about half way between empty and first quarter
thx
raven
I would start with a simple emissions test at a garage - any number of factors could be causing it:
Worn Spark Plugs
Exhaust/Manifold Leaks
Overfueling - though obviously this should be sorted by the ECU
Faulty 02 Sensor (or any of the other 26ish sensors in the engine!)
Incorrect Tyre Pressures
Rob
