stringy93
Changing Your Coupe Headlining From Grey To Black
Well after seeing a few black headlinings I decided that I needed one in my car! It took me a while to source a good black headlining with a sunroof cut-out but Quarry Motors came up with the goods in the end 
This is what you get - they supply it as a kit for £120. I purchased the black rear shelf at the same time which was an extra £20
A couple of before pictures
I started by disconnecting the battery. You will be working around the airbags later so I’d rather be safe than sorry! Then it is into the front to start stripping – removing/un-plugging lights, grab handles and sun visors etc
Then work your way back. I also removed the window rubbers. The B pillars will need removing - this involves pulling the top of your rear door card forward to get to the clips. You will also need to remove the bottom seat belt bolt to get it off.
The A pillars have screws hidden behind the ‘airbag’ strip
As you can see the headlining will start to drop
Out through the door. I recommend removing the front headrests to give you a bit more room. It’s a tight squeeze but it will fit!
I found to fit the sunroof shade it was easier to remove the sunroof glass. It’s only 6 screws but get someone to give you a hand!
In goes the new headlining and the refit is the reversal of the removal just using your black bits
Before putting the C pillars back in I fitted the rear shelf
I sprayed my window rubbers black using a rattle can. I did price up for replacing these but it was going to be silly amounts of money even second hand so for a few quid I’ve done the same job and you can’t tell.
brilliant! great job there it looks great, has got me thinking about changing mine :lol: where was it all from?
I got the kit from Quarry Motors in Sheffield, they do have a website but your best giving them a ring :)
craig your coupe is amazing dude top work, get those heated seats fixed :lol: haha
now for black interior :D:rolleyes:
Cheers dude, heated seats are the next DIY when I get time :D
Marty/mit - sorry guys but i deleted your posts so it was all together, im sure there was another way but this was the easiest.
Top DIY though!
LOL. No worries, have just dug out this thread to do exactly that.
Top work Stringy, fit looks great and window rubbers spot on - great tip!
Nice, I think it will be nicer if you make the door pillars grey all the way to the roof lining though? Just my 2p :)
Thanks for the comments :)
Did you have any trouble re-fitting the headlining?
No problems at all. The rear of the headlining hooks over at the back and then it just bolts up with the grab handles and visors etc :)
Umm yeah possibly, its just with the rear shelf being black now it might not look right going black-grey-black. Ive still got all the grey bits so I might give it a go sometime! :lol:
This was one of the few things I really wanted to do to mine. Was put off though as someone said the new one never really goes back in properly, bit like when ya pull up a professionall laid carpet if ya know what I mean? Did you have any trouble or is it all in and fitted exactly how the old one was?
Great write up Craig & a real neat job ! Good work indeed B)
Oh Nice Garden too ;)
Haha, cheers Daz. I cant take credit for the flowers only the grass but ill pass on the message :D
great stuff! B)
Cheers mate :)
Yeah I know what you mean mate. It went back in perfect, exactly how the old one was. Im very anal about stuff like that, everything has to be perfect :) Aslong as you dont bend it when putting it in through the doors it'll be fine.
