Dave Ci
Club-sport spoiler fittment.......
For those of you wishing to fit a Club-sport spoiler, then this is how it should be done..
Tools needed
8MM socket
19MM socket
Philip's screwdriver
Grease
7MM hss drill bit
1-3MM hss drill bit
Drill
Most important no one nagging you....oh and tie the kids up....
Remove the lip spoiler if fitted, this can be done using a plastic spreader, once a corner has started to lift, then you will be able to pull up the rest of the spoiler by hand..remember take your time...
Remove any left over 3M tape which holds these on...
Open boot-lid and remove the inner trim...
Once the inner trim has been removed, you will see four mounting holes, for the spacer's to be fitted into...
Using grease apply to under side of spacer and locate into holes x4..using a 19MM socket....
From the outside of the boot, apply masking tape...then from the underside drill through the middle of all four spacers using a pilot drill..ie 1-3MM hss drill bit...
Once all four pilot holes have been drilled, work from the outside in using a 7MM hss drill bit...
Offer spoiler to the boot as a test fit..before tightening spacer's and nut's..
Once in place..tighten spacer's and nuts...no need to swing on these...
Refit inner trim..and toolkit..
Finally finish item....... :lol:
great DIY there dave
looks mint too
dicky..you may have four little rubber O rings, the smaller one's, fit on the bracket base, then the larger one's fit on the inside before the spacer...
Hope it helps you out mate.... :lol:
Tools needed
8MM socket
19MM socket
Grease
7MM hss drill bit
1-3MM hss drill bit
Drill
Finally finish item....... :P
Oh looking soooo fine ! Pure Porn that is !! :lol:;);):D
Hope it helps you out mate.... :P
Yes I have, cheers mate ;)
What do you mean You ll get it on shortly ...isnt it on yet lol ?
It won't be on before the weekend, I didn't want to rush it and make a mistake so will have to wait till I have some more time :lol:
Hi Dave mate.
I am still catching up after a few weeks with little or no 'net. Didn't spot you'd done the clusport spoiler deed until following the fortunes of dicky's machine. Nice one mate.
Great write-up.
Personally I don't think I could ever bring myself to actually drilling my car though. I'd have probably just stuck it on with JB Weld!
Great write-up.
LOL. A mate of mine went to fit a bee-sting ariel to his mk2 Golf once and slipped with the drill leaving a line across half the roof!!!!!
Hi Dave mate.
Hi Simon..
Thought ud won the Loto ;) ??
Couple of pics on BMWCC... :P
does that spoiler affect the automatic opening of the boot?
parents car has a spoiler and when clicking the boot on the key fob it cant push it open coz of the weight, meaning u need to open it manually.
Nope I have the same Clubsport spoiler and the remote boot opening is still fine :lol:
Hey Dave......... That looks like a well sexy boot lip spoiler lol
For all of you running big base and worried about fitting a clubsport incase it rattled off it doesent 3 years ive had my one on with 1000wrms in the boot and it still fits loveley and feels firm with a lot of heavy b line. best factory spoiler for an e46 luving it.
