Danw8986
Installing Bmw Diagnostic Software
Aha! I bought the same thing! :P
If you got the 6.5Mb installation instruction .pdf that came with it like I did, go back to page 4/5 and ensure you've set the com port correctly. That was my problem 1st time around.
OK,
I recently did this and had a few problems. What is the error code that your getting?
Also, check under the bonnet to see if you need the 20-Pin round connector too, that was my issue. I needed the blue one to plug into the USB port on the laptop, and I needed the plue ODB port to plug into the black 20-Pin connector. This then resollved my issue.
However, it would help id I knew what fault code that INPA gives you.
i get to page 25 of the instrucion pdf when you plug the laptop into the car to check its conectiong but it just says "unable to comunitcate" my cars a 2004 330 so im preaty sure it wornt need the old type obd also.
i have the same acble, from the same seller with no issue at all
as INPA does not need bmw diaghead, or VM ware, this most likely points to a USB - Cable connection issue, a few pointers
make sure you always use the same usb port, follow his Instructions to the letter
when the cable is plugged into the port on the car, does the red LED light up on the cable head?
in XP CTRL Panel, System, is the port showing?, if so, what port is assigned to it. i always use port 1
regards
Edited by siffion
still unable to send PM, was gonna send you my moby number, to talk you through it later on after work
thats very kind of you, ive completly cleared it now so should work if not ive sent you a pm with mine
Take everything out of your USB ports, nothing plugged in at all. Boot into Windows XP and once all is booted up properly, load up Device Manager from the Control Panel.
Here, you can see your devices including the ones plugged into your USB ports. Plug in your cable and then click properties for this device. You then need to ensure that it is Set to COM1 on the port settings under advanced.
This will assign COM1 as the port on this particular USB Port, so remeber which one it is that you have plugged into.
Then try that.
If you don't have any luck Dan, I'm more than happy to look next time you're up here visiting the other half.
cheers gaz if i havent got it working by the week end im up your way than so will be giveing you a phone call begging for help lol
ok guys im looking into the com ports now when i go com port 1 > advanced i get a different screen to the one on the pdf instruction guide (see pic below) sorry for the dodgy pic the laptop im on isnt connected to the interweb. the screen to the left is what ive got the screen to the right is what i should have
Edited by Danw8986
You're doing it on XP whereas the guide is for Win7 so it'll be slightly different.
com 2 shows up in the layout it should be tho. any ideas on what the settings should be on this screen ?
Edited by Danw8986
