Fredo
Help - Steam From Radiator....
Good morning all,
I would be greatful for any advice you could give me with my car trouble...
The other day I noticed a little "steam" comeing from the grill's in trafic, and assumed is was just moisture on engine as the tempreture guage in the car never goes above middle. But This morning as I parked at work I noticed it again. I opened the bonnet and pulled of the plastic cover to get a good look at the radiator. It is very hot at the top, but the rest is ice cold. Also there is coolant under the radiator as well as some splashed about the fan.
Any ideas??
Your radiator or expansion tank might be leaking, common weak points on the E46.
Would be a good idea to let the car run so you can see for yourself where the leak is coming from?
Update. It turns out the rad was not hot at all! So I have changed the radiator, expantion tank, water pump & thermostat. Put in frash cooant at the correct mix, and it is still the same. I have bled te system correctly (got alocal BMW garage to check it). I am not at my wits end. Any ideas? I have started window shopping at other cars so suspect the Beemer and I might soon be divorced........
If it's not overheating and you've done a full cooling system overhaul, then i'd say leave it. No point spending money if the only symptom is a bit of steam. Are you sure it wasn't coming fron the heated washer nozzles? If you're looking at it from behind the wheel in traffic then it could be coming from further up the bonnet.
