Razza77
Guide To Coding With Ncs Expert
"CYCL_TI_BLK;1-touch on turn signal blinks. einmal-1 . zweimal-2 . dreimal-3.
One touch indicators, lane change.
BLINKIMPULS_WARNBLK to wert_04 - double impulse hazards
HHS_AUTOMATIK - enable auto rear window fogger
(I haven't found the last three in any module, but I can see it in the full read-out. So if you find it, then tell!!)"
Have you found a way to setup any of these 3 settings? The touch on turn signal blinks would be nice to have. I also see them in the full 61kb read-out.
You'll need an LCM with sw4.0 or higher for the turn singles. Only found in very late 2004/5 cars.
HHS_automatik should be in the HVAC module.
Double hazards are in the LCM. I get MOT failures for them though, so be sure to change them back come test time :)
