Tim-Ci Posted May 11, 2017 Report Share Posted May 11, 2017 (edited) Ah fair enough I guess the tyres/suspension/remap could all explain why the DSC is a bit frisky on a bumpy road. If you do check out the things I mentioned then I guess at least you'll know the DSC is working with proper data and your alignment is okay. Edited May 11, 2017 by Tim-Ci Link to comment Share on other sites More sharing options...
X-Man Posted May 17, 2017 Report Share Posted May 17, 2017 Not been here for a while but finally got around to doing the Valve Cover Gasket. Took me longer to get the old gasket off the cover than it did to do the job as it was basically brittle plastic! Sent from my iPhone using Tapatalk Ruesta 1 Link to comment Share on other sites More sharing options...
Foe Posted May 21, 2017 Report Share Posted May 21, 2017 (edited) Replace the Off side inner tie rod. I must say it was easy enough job, but didn't realise how much this rod impacts the steering so much. Just need tracking no. And finally replaced both front wings! Before and after Edited May 21, 2017 by Foe Big gap Markxr and Ruesta 2 Link to comment Share on other sites More sharing options...
Ruesta Posted May 22, 2017 Report Share Posted May 22, 2017 16 hours ago, Foe said: Replace the Off side inner tie rod. I must say it was easy enough job, but didn't realise how much this rod impacts the steering so much. Just need tracking no. And finally replaced both front wings! Before and after That's quote a difference, must be nice not having to look at that damage any more :-) Foe 1 Link to comment Share on other sites More sharing options...
Foe Posted May 22, 2017 Report Share Posted May 22, 2017 Thanks. It really does make a difference. Nice now, its not looking like a crapper. Ruesta 1 Link to comment Share on other sites More sharing options...
Markus5000 Posted May 28, 2017 Report Share Posted May 28, 2017 About to paint my (oh for Christ's sake just starting to rain)...... Front lower grill black. Fingers crossed the rain buggers off :/ The_Judge_ and Ruesta 2 Link to comment Share on other sites More sharing options...
Wrighty74 Posted June 4, 2017 Report Share Posted June 4, 2017 Finally fitted a new radiator and fan switch in the old girl this weekend The old one was like a banana Ruesta 1 Link to comment Share on other sites More sharing options...
Markus5000 Posted June 5, 2017 Report Share Posted June 5, 2017 Got the 330d mapped and the shift bearing replaced. Now slots into gear smoooothly TriggerFish, The_Judge_ and Foe 3 Link to comment Share on other sites More sharing options...
Foe Posted June 5, 2017 Report Share Posted June 5, 2017 6 hours ago, Markus5000 said: Got the 330d mapped and the shift bearing replaced. Now slots into gear smoooothly How was was it to sort the shift bearing? Markus5000 1 Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2017 Report Share Posted June 5, 2017 Nice. Who mapped it? About 45 minutes it took me to do the bearing. Including a screw up on my part. Markus5000 and Foe 2 Link to comment Share on other sites More sharing options...
Foe Posted June 5, 2017 Report Share Posted June 5, 2017 So yesterday I did the following; Oil, fuel and air filter change. Replaced the FSR that was a faff! But I still have a humming sound from the front of the dash, sort of behind front vents. Annoying! Also changed the pollen filter and also an oil change. Link to comment Share on other sites More sharing options...
Foe Posted June 5, 2017 Report Share Posted June 5, 2017 3 minutes ago, TriggerFish said: Nice. Who mapped it? About 45 minutes it took me to do the bearing. Including a screw up on my part. Do you have a guide for the shift bearing? Link to comment Share on other sites More sharing options...
Markus5000 Posted June 5, 2017 Report Share Posted June 5, 2017 30 minutes ago, Foe said: How was was it to sort the shift bearing? Guy that mapped it did it. Took him about 20 mins. He said it was dead easy Foe 1 Link to comment Share on other sites More sharing options...
TriggerFish Posted June 6, 2017 Report Share Posted June 6, 2017 10 hours ago, Foe said: Do you have a guide for the shift bearing? Rough guide, but you should be able to figure it out: Remove interior trim bits so you can see the cup/bearing. Jack up car Locate the gear shifter mechanism under the car (I had to move the heatshield slightly to give myself proper access Remove the clip that goes over the end of the shifter rod coming from the gearbox and slide this out of the gear lever. At this point, the gear lever is now from from the gearbox. From above, remove the gear lever/bearing from the holder (I smashed mine with a screwdriver and hammer) Insert the gear lever into the new bearing (this has to be done first! I forgot, and spent ages trying to coax the new one out of the bracket without breaking it) Push the bearing/lever combo into the holder. Go back under the car and push the shifter rod into the gear lever, and then push the little clip over the end of the shifter. Replace trim/heatshield. I spent most of my time fixing the c**k up in 6, and manipulating the heatshield (made much harder by only jacking up one corner too!) Markus5000 and Foe 2 Link to comment Share on other sites More sharing options...
Markus5000 Posted June 6, 2017 Report Share Posted June 6, 2017 12 hours ago, Foe said: No idea why this 'Foe said' bit is still showing! :/ 1 hour ago, TriggerFish said: Rough guide, but you should be able to figure it out: Remove interior trim bits so you can see the cup/bearing. Jack up car Locate the gear shifter mechanism under the car (I had to move the heatshield slightly to give myself proper access Remove the clip that goes over the end of the shifter rod coming from the gearbox and slide this out of the gear lever. At this point, the gear lever is now from from the gearbox. From above, remove the gear lever/bearing from the holder (I smashed mine with a screwdriver and hammer) Insert the gear lever into the new bearing (this has to be done first! I forgot, and spent ages trying to coax the new one out of the bracket without breaking it) Push the bearing/lever combo into the holder. Go back under the car and push the shifter rod into the gear lever, and then push the little clip over the end of the shifter. Replace trim/heatshield. I spent most of my time fixing the c**k up in 6, and manipulating the heatshield (made much harder by only jacking up one corner too!) Nice guide bud :). Today, I have mostly been enduring torrential rain while changing all my badges Link to comment Share on other sites More sharing options...
Foe Posted June 6, 2017 Report Share Posted June 6, 2017 Thanks for the guide @TriggerFish TriggerFish 1 Link to comment Share on other sites More sharing options...
Markus5000 Posted June 8, 2017 Report Share Posted June 8, 2017 Put my e46zone stickers on today. Despite the postman's best efforts to f**k them up by screwing up the envelope to get it through the letterbox (letters on the stickers came off on the backing grrrrr), they went on OK Thanks #sam The_Judge_ 1 Link to comment Share on other sites More sharing options...
bachu Posted June 9, 2017 Report Share Posted June 9, 2017 Il be having the rust taken out the rear arches new wings fitted, alloys resprayed silver so it will look good for the bmw show in July... anyone going to that? Wrighty74 1 Link to comment Share on other sites More sharing options...
DaveNE Posted June 9, 2017 Report Share Posted June 9, 2017 all mini related is that allowed Replaced and coded Air bag ECU (stupid mini ) Replaced track rod ends x2 (F*&^ing Mini) Replaced Balljoints X2 ( god I hate this car ) Replaced wheel bearings x2 ( with a passion ) Replaced Handbrake cable Replaced Font and rear discs & pads. So thats that thing through its mot this year. Thank god its the Mrs Car did I mention that I hate Mini's At least I can now get back to the Coupe Foe 1 Link to comment Share on other sites More sharing options...
Wrighty74 Posted June 9, 2017 Report Share Posted June 9, 2017 Put it in for a much needed oil/filter change,also a engine flush at National tyres Happy with the service and car seems to be happy too😎 Link to comment Share on other sites More sharing options...
Markus5000 Posted June 9, 2017 Report Share Posted June 9, 2017 (edited) On 05/06/2017 at 21:48, TriggerFish said: Nice. Who mapped it? About 45 minutes it took me to do the bearing. Including a screw up on my part. Paul at Autotorque in westcott mapped it Edited June 9, 2017 by Markus5000 Link to comment Share on other sites More sharing options...
BOB_330 Posted June 12, 2017 Report Share Posted June 12, 2017 Have changed the front wishbone bushes to powerflex, handles much better now. Link to comment Share on other sites More sharing options...
Tim-Ci Posted June 12, 2017 Report Share Posted June 12, 2017 Sounds good Bob. I was thinking I might do mine for more precise steering at some point. Did you get the bushes only and press them into the aluminium housing, or did they come as an entire assembly? Link to comment Share on other sites More sharing options...
BOB_330 Posted June 12, 2017 Report Share Posted June 12, 2017 6 minutes ago, Tim-Ci said: Sounds good Bob. I was thinking I might do mine for more precise steering at some point. Did you get the bushes only and press them into the aluminium housing, or did they come as an entire assembly? I ended up buying the powerflex bushes pre-installed into the lollipops as I didn't have a press to push the old ones out. Glad I did because the old ones looked like they would've been an absolute bugger to get out the lollipops. I bought mine from some guy on eBay, I think theres only a couple of sellers who do the pre-installed ones on there. Link to comment Share on other sites More sharing options...
Tim-Ci Posted June 12, 2017 Report Share Posted June 12, 2017 (edited) Cheers, I recently replaced my Meyle HD ones with OEM barnd Lemforder ones, as one of the Meyle ones was coming apart and I had got a vibration at about 50mph as a result. I think there might be a bit less steering feedback with the Lemforder ones, with the Meyle's it wasn't that great to be honest either. I will have a look on EBay and see what Powerflex ones I can find. A bit more steering feel would be great. I've got the front toe almost neutral so the car should be sharp at the front end, but it doesn't seem to go around small roundabouts very sharply, I'm hoping the Powerflex bushes might help with front end bite. I know the front tyres are smaller so this does cause the car to want to understeer, but I think (hope) there's still room for improvement. Edited June 12, 2017 by Tim-Ci Link to comment Share on other sites More sharing options...
