Jamie330d
Jamie's Wide Touring
Ill go for them for ya.
There might be a forwarding issue though
sent with tapatalk pro that mr feva can't use
What's the forwarding issue? They'll be bolted to your car? lol
You a clever man Jamie don't trust him, it's the only way he'll get a set.
Sent from tapatalk pro now working since update. At last I can quote
:-D
f**k doing that drive for a set of wheels! Can't a local member collect and courier them for you?
Some couriers do a drop in service!
I'd do it if I was closer but Oxford is an hour from me. My little sister goes to uni there.
Yeah in getting them at a good price so I don't mind.
Fitted my big brake kit today :)
FD18BA93-BBF9-4879-872E-594EF8F46D4B-733
795596AC-7C6E-4835-9BB7-21574A65F65E-733
487C1B0A-BB09-44E6-86DE-FB17861AE658-733
Had a few problems fitting them, had to cut the back plates so they cleared the discs, the rear carrier bolts were badly corroded so were just rounding, the pads were a fraction of a mm to long so had to be modified, one of the bleed nipples had been cross threaded into the caliper so wouldn't stop leaking, eventually we bled it up then blocked the nipple off with a weld because we couldn't get another nipple in, and had to replace the brake pipes due to corrosion and them snapping whilst trying to fit the stainless flexi's.
Overall they look good so I'm happy :)
Should really have checked the calipers over before attempting to fit them especially since they were an 'unknown' - you could have had the bleed nipple re-tapped or helicoiled.
I take it you're not impressed by them since you only mention that they 'look good' rather than perform well?
....and as Momo said...WTF is going on with that arch....never mind the paint looks like a load of filler has come out...looks pretty deep?
Edited by L333JSA
The wing is damaged, because its on those s**t wheels they caught the inside of the arch, bent the metal and cracked the filler, they're sorting it for free I just need a day that I'm off so I can leave the car with them, they're also going to sort a small bit on the back bumper.
I can't really check how well the perform because I only finished fitting them late last night and I believe its 50 miles to run in new pads before driving hard on them as they won't bed in properly. The thread was pretty much totally gone from the caliper which is why it wasn't helicoiled, the weld works and does exactly what I need so I'm not fussed, realistically they were only £400, if they were totally f**ked then I'd be pissed off but given what I paid can't expect them to be perfect. Working and safe but not perfect.
I have a young son who goes in the car, if I thought for a second these weren't safe they would be removed right away and standard kit put back on.
Edited by Jamie330d
Sounds like a bodge, hope they do what they're supposed to. <br /><br />Sent from my GT-I9505 using Tapatalk<br /><br />
it does sound like that but it's actually ok, new bolts for the rear, new brake pipes all round, and block the bleed nipple off, so sounds worse than it is.
So perfect for helicoiling then really lol
I said that to the guy he said it wouldn't work, not entirely sure why but tbh helicoiling is something I've never had to do so I'll take his word for it, he's a mechanic I'm not.
