Ruesta
creaky rear end
Hi all.
My 2000 328 coupe has been making an annoying creak from time to time somewhere at the rear end. This has come and gone since I've had her but recently its got a little worse, more often and there's also now a kind of squeaky rattle.
It only really happens as I pull away from a stop or as I'm pulling up to a stop, and the creak happens at low speeds usually when turning right at roundabouts.
The squeaky rattle is not constant, it just does it a bit as I pull away and again when I'm coming to a stop.
I can make it do it ever so slightly when I'm stationary with the breaks pressed as I put it in and out of drive (its an auto by the way) but only as it goes into drive, not back to neutral.
Any ideas anyone?
Its not the exhaust, I've been over that idea, but its definitely coming from the rear end, and perhaps the nearside rear.
I'm at a loss as to what it might be now and would like to get some idea b4 taking it to a garage so they can spend my money fault finding.
Appreciate any ideas, even just to rule things out.
TURNS OUT ITS THE DREADED SUBFRAME ISSUE - HELP!!!!! I'm so gutted:'(
Edited by Ruesta
I haven't checked the springs and wouldn't know how to check the top mounts but it does seem suspension related to be honest.
When I pulled up here at work after lunch I sat there with my foot on the break and moved it between D, N and R. Each time the car tried to pull forward or back it made a short squeaky creak (thats the best way i can describe it really).
Other than that the only time i hear any creaks and squeaks similar or for a little longer is a very low speed, slowing to stop or pulling away. And occasioally when turing right.
I reallty hope its not the dreaded subframe issue too - I've finally got here looking rreally good paint wise, its had new wings, front bumpr etc.. and I've had new front breaks done, and various other bits. That damage to the floor in the picture above looks pretty terminal, be such a shame.
Is there an easy way I can (hopefully) rule this out/check for it easily without getting it up on a ramp?
It doesn't really make much noise when I push it up and down by hand.
Obviously my next step is to get here booked into the garage and up on a ramp to have a good look, prod, poke and tug but I would prefer to have a look at anything i can my self prior.
Thanks for the input guys - can always rely on a quick responce on here, its very much apreciated.
Edited by Ruesta
Unless you can get under the car it will be difficult to find a cracked subframe, though it could be worth stripping the inside of the boot back and taking a look from the top.
Springs = Jack car up, remove wheel, remove bottom bolt holding damper in position, push down on trailing arm, pull out spring. Take a good look at it whilst its out and check it over for rust/damage.
Also whilst you have the damped unbolted from the trailing arm you can give it a good wiggle to check for excessive play in the rubber bush in the top mount.
Thanks Simon
I recently found my spare wheel well rather wet so I've already got a fair bit of my boot stuff still out so removing the rest shouldn't be a problem.
You make removing a rear spring sound very easy, is it really that simple? My mechanical skills are rather basic. I've changed break parts etc... serviced my own cars but not done any suspension related work.
Be really good if it was just a knackered spring or damper though, the noise does get on my nerves and is a little concerning. Especially since I often have my girl and our American bulldog in the car - need to know its safe. Its just come at a really bad time, after spending out just short of a grand last month on a operation for the dog - he's not insured - so funds are rather limited.
I'd say top mounts mines stopped squeaky since I changed mine, I did have a broken spring so I changed the whole suspension but forgot to buy top mounts so had to use the old ones, and it still squeaked, bought new top mounts fitted them in 10 mins ( you don't even have to take your wheels off!!!) the hardest part of the job is removing the trim in the boot, cheap part to! Follow this guide on youtube (it is an E36 but it's very much the same) I used this when I did mine
http://www.youtube.com/watch?v=DKZ4rs8vNz8
Edited by Tymm
Ok cool, thanks for the advice chaps, really appreciate it. I will start there.
I've just managed to replicate the noise with the car parked as it goes something I've not managed up till now..
I started to remove the few bits left in the boot, along with the carpet and board over the wheel well, and thought to my self... I haven't pushed it up and down with the boot open before, only with it all shut......
Sure enough, when pushed up and down hard enough, with the boot open and spare wheel well exposed it creaked like a b'start. Sounds like its coming from the area behind where the satnav/cd changer etc.. is - obviously the suspension. Its really creaky/squeaky, not the sort of sound I would associate with a broken floor, personally.
So the E46 Zone comes to the rescue again! Thanks muchly - it really does sound like a spring or top mount as suggested, and when I got a colleague to do the same, with my head under the car it sounded like it was coming from the suspension arm area.
Good news I think/hope. Springs are fairly cheap aren't they?
I enquired about a new rear backbox from BMW a few weeks ago - they quoted over £400 quid, just for the backbox - One of my brackets was broken but rather than change the backbox I've made a new bracket with a stainless steel band round the backbox - saved about £390 quid!
:thumbup:
IIRC springs are about £80 a side. Top mounts are even less, probably around £20 or so.
A relativly cheap fix then, and a job I can tackle - some good news at last.
Thanks again!
Meyle HD top mounts here reasonably priced
http://bit.ly/1dSBHOe
Known to clunk though, the Lemforder ones are a better option and cheaper from allgermanparts
really? i was just going by the assumption Meyle HD stuff was decent
It is, I have Meyle HD stuff fitted to my car, but there is an issue with the rear top mounts where they can make a knocking sound
The Lemforder ones are identical to the genuine BMW ones and more than likely made in the same factory
Ahh thats wicked, thanks muchly. May as well start with those then as they're so cheap and won't be buying the Meyle ones, its annoying noises I'm trying to get rid of so a cluncky rear end aint that much better than a creaky rear end, well excluding the fact its a new, unworn part of course - thanks for the advice.
Watched the DIY I was kindly sent a link to and it all looked fairly simple. Obviously while its jacked up I will take the other bit of advice and check the springs.
Thanks agian for all your input everone, this place always comes good and has saved me a fair few quid just in fault finding time alone.
I will report back on what exactly gets rid of my annoying creaky rear end as soon as its done.... - (in the new year I would expect)
I have the meyle hd and don't get any clunking
Some people on here have though, so I'd rather not risk it personally, especially when Lemforder make oem BMW parts and they are so well priced
