Dee330Ci
Carbon cube interior
Well, had the lovely task of replacing this over the weekend:
All went well, had a denso fsr and whoever did this, did me the favour of leaving the 2nd torx so I didn't have to fight it, so thank you lol!
Whilst I was in the car, I thought something needs brightening up a touch, so the interior went from:
To this:
I think this breaks up the black interior just right, the pics look more blue than in real life.......options please?
Thanks,
Dee
Really nice results,
How did you paint them in carbon cube style? I thought the only way is to vinyl wrap all the trims. Is it easier?
Thanks
The cube pattern is a metal facia so this comes trough the paint.
Thanks
Could you please share some of the information on how to do it? Like what type of primer and paint did you use? And can I be 100% sure that it is metal facia as my one seems to be plastic? When I knock it with fingers it doesn't sound like metal really but my one seems to be original ones. The pattern is 3D cubes and it is possible to feel the texture of the pattern. It is quiet difficult for me to explain so I will try to post some pictures later of the current state of my trims. Thanks.
Thanks
Mine is definitely a metal fasica, you can see the it from the edge of the trim.
What I did was;
Clean with a stiff bristled brush with water and a bit of washing up liquid.
Rinse thoroughly.
Wiped down with meths, wait till dry.
Wiped down with panel wipes, again wait to dry.
Sprayed two light coats of grey halfrauds primer, waited about and hour to dry between coats.
When I re-did them black; used halfrauds satin black, two/three coats was sufficient, waiting around half hour/45 mins to dry between coats.
When I did them the grey, used the same primer and then used ford sea grey from halfrauds again.
Bobs your uncle :)
Thanks
What I did was;
Rinse thoroughly.
Bobs your uncle :)
Thank you very much, sounds a lot easier and of better quality than wrapping with vinyl. :) Also it seems like there is a lot less hassle to spray it. I hope my one is metal facia as well. And do you know if metal facia was a standard for all BMW sport models? My one is 320ci sport year 2003 facelift.
Edited by Chockis
Metal finished interior trims weren't standard, it all depends on the trim type that was specified when new. IIRC it's only the 'cube' (black or silver) & brushed aluminium that is actual metal. The rest is either wood or plastic.
Edited by bungers
Here are some pictures. Please confirm if it's safe to prime and spray paint my trims? Now when I had a closer look it seems like it can be some kind of light metal like aluminium, as the scratches are shiny, and it is slightly colder to touch than plastic :D I know it is not very scientific description but... :D
http://i1166.photobucket.com/albums/q608/Chockis/10566675_10152507802843567_102462077_n_zps5a3aa60e.jpg
http://i1166.photobucket.com/albums/q608/Chockis/10521877_10152507802553567_243129396_n_zpsb8a76f99.jpg
http://i1166.photobucket.com/albums/q608/Chockis/10563415_10152507802203567_153908156_n_zpsdadf77c5.jpg
http://i1166.photobucket.com/albums/q608/Chockis/10551944_10152507743303567_1969458684_n_zps0d4fb4b5.jpg
Edited by Chockis
That's the same as mine, although some of those scratches seem really deep so may show through, even then a couple of rattles cans won't cost much just to try it out.
Yeah, they're aluminium carbon cube; should come up a treat once painted.
Yeeeee!!! I'm so happy now! Thank you guys so much! I'll post some pictures when I finish refurbishing them. ;)
