320cdw
2004 320cd what goes on here?
Hi all,
Got the 320cd home and started to check out all the stuff I knew goes wrong, upon doing so I found this....
post-30813-0-27816500-1398314066_thumb.j
Zoomed in....
post-30813-0-00896100-1398314092_thumb.j
Does anyone know what connects to this tube? or is it nothing? It looks like some sort of diaphragm valve thingy...
Thanks in advance...
D
There should be a vacuum pipe connected. It'll help your mpg getting it working again, although I can only think something is wrong with it, hence the previous owner disconnecting it. Here's a diagram which should help:
Ha! I just found the exact same diagram lol, there's a lot of stuff the previous owner had played with, cars a mine field, it's a laugh though...
It looks like the recirc valve on a turbo which is used to dump the air pressure made by the turbo when coming off throttle. The vacuum hose that is supposed to be attached there allows the valve to open and close to match throttle response and regulate the air flow. Otherwise you are constantly boosting the engine.
I may be wrong as i have never owned a TD before, so it could be completely unrelated.
Bungers,
Had a look at the RealOEM page again and noticed this...
post-30813-0-30871800-1398381950_thumb.p
Does this mean it shouldn't be there because the product has been discontinued? Or does that just mean they don't sell it anymore...
No it should definitely be there. They stopped production of it in June 2013 apparently. It's used on lots of different cars & for different applications. According to realoem the replacement part number is 11658507249 - this may be a generic p/n for the vacuum hose which the dealer cuts to length. Personally I'd just get some silicon tubing.
Did we ever figure out what it actually does though? Plus we know where one end plugs into, but what about the other? I expect you have a vacuum leak somewhere unless the other end has been properly plugged.
Yeah, it is an actuator for the 'venetian blind' on the radiator, I think it keeps the blind closed to help the car warm up quicker then once warm it will open it to allow the engine to be cooled by the viscous... the pipe goes down to a small electronic valve as per the pics above..
