Bennp2000 Posted September 9, 2014 Report Share Posted September 9, 2014 Am I right in thinking that with factory fit Xenons I should have a lever under the protective cap with which to change my headlights so they're suitable for use over in Euroland? Link to comment Share on other sites More sharing options...
Larry D Posted September 9, 2014 Report Share Posted September 9, 2014 Yep, there is an adjustment, it's a plastic knoby arm thing behind the projector, don't believe you have to remove anything at all to see it momo 1 Link to comment Share on other sites More sharing options...
CharlE46 Posted September 9, 2014 Report Share Posted September 9, 2014 On the facelift saloon/tourer xenon's the adjuster is inside the headlight, to access you remove the low beam cover. Do the passenger side first as you can just about peer inside and see the little white lever, push it up (or down can't quite remember) and it flattens the beam pattern so no side kick up. This is the lever your looking/feeling for inside the housing (this light I'd stripped down obviously) Access through the low beam, both sides it's on the side nearest the high beam (this isn't an xenon but gives you the idea) Someone asked the question a couple of years ago when I was rebuilding my lights hence the photo's HTH Charlie Link to comment Share on other sites More sharing options...
Bennp2000 Posted September 9, 2014 Author Report Share Posted September 9, 2014 Thanks, that's very very helpful. I'll give the small hands job to my other half (I need to change a bulb already). CharlE46 1 Link to comment Share on other sites More sharing options...
