Dicky
Coupe Sagging Door Seal Fix
As per title here is my guide to repairing you door trims on your E46 coupe, now this is what I did on my car and it worked a treat so I thought I would share it with you, and hopefully save you a few quid.
This is a well known fault and BMW give this response SIB 51 12 04 Issued November 2004, Titled Door Protection Seal Peeling Apart. Cause identified is insufficient bonding between rubber and flock-coated portion of the door edge protection seal.
So your door trims are sagging down, so what are your choices:-
1.) The problem part number is 51 71 95 37 00 so if you are buying second hand or not from BMW you don't want this one as it will probably be in the same shape as your out going one.
2.) The new part number 51 71 71 61 687/688 Black Door Edge Protector which will be a direct replacement, but these are expensive nearly £200 a side!
3.) You can repair your current ones, which is what I did and save £400.
So when I first got the car, I tried to fix this with No More Nails Tape Strips, now this did the job and kept it up out the way, but it did look a little unsightly.
So I removed all the old tape and cleaned it all up and it was back to its old sagging state and a bit of peel at the B pillar had now appeared as well.
Also a bit of peeling down the A pillar
So I bought some contact adhesive.
Then as per instructions, spread it all over the inner door trim and all over the remaining side still on the car, left it to be touch dry which was about 10 minutes.
Then pushed it all back in place, making sure that it all sat nicely as you can’t really adjust it once the two sides touch. Now I thought about just leaving it but didn’t want gravity to play any part in it, so I used Gaffer Tape to pull it in nice and tightly.
Then after about an hour I removed the tape carefully and job done and it looks as good as new, because I had used gaffer tape I knew it would stick nicely to almost anything to keep it all in place. There was a bit of residue on the glass and paint but this wasn’t to hard to get off with a little elbow grease.
Edited by Daz 330 Cs
Well done ;) Only thing is that that glue is the same stuff i used first of all. Its good for about three months, but when it gets hot it comes apart. Well mine did ;):lol: Hope it sticks for you though, as i tried cleaning the old crap off, but some was still on there, so might of been that. :P
Oh bugger, well I hope it holds up I think it should do all nice and clean and held in place, at least the write up will be the same, we will just change the product depending on how we get on ;)
To anyone interested in the above, i tried Araldite (had some sitting around), now i thought this was supposed to stick just about anything to anything! Not true, it lasted all of 1 day and came apart, will be looking to get some of the above glue to sort ASAP.
Yes waiting for this too. Mine hangs down really bad on both sides now, stuck back with sticky pads, good for 1 day.
i used mitre bond an that too is good for 3 months or so, the damn door trims are the worst part of the e46
but nice1 dicky!
Lee131
Have you tried using the worktop clamps in conjuction with the Ever Build Mitre Bond should last more than 3 Months then .
You can get them in zinc plated or stainless lol !
Might have a brilliant solution to this one. Got a product called CT1. Its a kind of silicone, available in black/clear and white etc etc. costs about £10 a tube but will stick anything to anything! Will give it a go and report back. Well mine are actually ok at the moment, but might try it anyway :DB)
Might have a brilliant solution to this one. Got a product called CT1. Its a kind of silicone, available in black/clear and white etc etc. costs about £10 a tube but will stick anything to anything! Will give it a go and report back. Well mine are actually ok at the moment, but might try it anyway :lol::D
This is the same as silicone sealant. Have you ever got that stuff on anything you weren't trying to glue together or seal? It's impossible to get off, so should do the trick nicely lol :)
This is the same as silicone sealant. Have you ever got that stuff on anything you weren't trying to glue together or seal? It's impossible to get off, so should do the trick nicely lol B)
:D Yeah but its good stuff, and all the other ones are poo, so worth a go :)
Just for your info it has been over 6 months since I did this fix and it is still holding as good as new and I sometimes worry as I have to rub against it if getting in in a tight parking space and its still all good :)
