Markos_46 Posted February 15, 2016 Report Share Posted February 15, 2016 Im new to BMW diesel engines but bought a nice clean early 330D touring at the weekend via ebay - lots of history with the car and drives Ok but is seriously lacking in the boost dept and has no ooomph when you put your foot down using the kick down on the auto box. Before it goes to the garage - any ideas on what to look for? I cant really hear the turbo spinning but I can hear a sort of whistling sound like a vaccum pipe leaking somewhere - doesnt really feel like it has a turbo on it but got the car cheap enough so cant complain too much. Any help would be appreciated - thanks Link to comment Share on other sites More sharing options...
rasa Posted February 15, 2016 Report Share Posted February 15, 2016 (edited) sounds like boost leak,or maybe failing maf sensor,easy checks first,worst case turbo seals,check for oil mist deposits and or oil leaks also,get a good strong lamp and take engine covers off, Edited February 15, 2016 by rasa Link to comment Share on other sites More sharing options...
The_Judge_ Posted February 16, 2016 Report Share Posted February 16, 2016 It could be really simple and you just need to do this: http://www.e46zone.com/forum/topic/4012-throttle-adaption-reset/ Believe me it works! Link to comment Share on other sites More sharing options...
TriggerFish Posted February 16, 2016 Report Share Posted February 16, 2016 The vacuum hose to my turbo from the actuator had a split once, meaning no boost until 3k rpm. Easy and cheap to fkx, just took me a while to Trace it! Link to comment Share on other sites More sharing options...
Markos_46 Posted February 17, 2016 Author Report Share Posted February 17, 2016 Thanks I'll check these at the weekend - started it up last night and couldnt hear the turbo at all so god knows whats going on, hopefully something simple like a hose ha ha Link to comment Share on other sites More sharing options...
Markos_46 Posted March 2, 2016 Author Report Share Posted March 2, 2016 Quick update if anyone cares ha ha - changed all the vaccum pipes which had all seen better days, de-swirl flapped etc etc put it all back together, still no boost but looks like its the turbo actuator - if you manually operate the actuator, turbo spools up nicely - let go of the actuator and rev, no boost. Its an early vaccum operated type so on the hunt for 1 of these - if anyone can point me in the direction of someone or somewhere I'd appreciate it. Link to comment Share on other sites More sharing options...
TriggerFish Posted March 2, 2016 Report Share Posted March 2, 2016 Same as the erg one, so if that's blanked off, just swap them over Glad you're getting somewhere! Link to comment Share on other sites More sharing options...
Markos_46 Posted March 15, 2016 Author Report Share Posted March 15, 2016 Changed the turbo pressure regulator and still nothing, still have a 1E30 error showing (1E30 Boost Pressure Regulation or Actuator) The actuator arm moves freely & tested the diaphram with a minivac - took the car for a spin with the minivac attatched to hold the actuator in place for boost and the car flew so no problems with the turbo, the actuator or the turbo pressure regulator or the vaccum pipes - problems looking to be what controls the turbo pressure regulator now - I've read about 2 charge pressure actuators? Any info on these? Link to comment Share on other sites More sharing options...
Markos_46 Posted March 21, 2016 Author Report Share Posted March 21, 2016 FIXED! 1 of the connections under the inlet manifold that has a vaccum pipe on was blocked solid - drilled out, cleaned etc & all sorted. TriggerFish, chocka and The_Judge_ 3 Link to comment Share on other sites More sharing options...
