gibbo
Engine missing
Hey guys
Im new to e46's, and this site.
just recently bought one, 2003, 316i with the n42 engine I think.
Having been an e30 fan for the last 14 years I was let down badly with my 325i cab, I decided to move on to the e46.
I thought the newer model would mean no problems, but yet again, BMW's have let me down, but I still love them.
It happens when I start to give it some throttle, gentle throttle seems worse, the car starts to miss,
if I could best describe it, its almost like an automatic, when you give it throttle and you get the revs changing as its going through gears, (mine is a manual)or maybe its like its hicuping.
I'm not sure if its a common problem, but have found alsorts here on the web, from its normal because of not having a throttle cable but electronic, to going to the dealer to get a software update.
it has a full service history, but not a full stealer history, more so local garages.
Any help much appreciated..
There is a throttle reset procudure you can do yourself on here somewhere, might be worth a try?
A throttle reset? sounds a good starting point, any idea how to search on here for it?
Forgot to say earlier, the car has had new coil pack recently, I guess the previous owner had the same problem, but neglected to tell me.
Click the link in Marty's post above^^^^
Sorry, just seen your link to reset throttle
LOL.. Sorry, i didn't add the link straight away as i had to go search for it myself,
anyway to search something just select the SEARCH button at the top right hand corner of the page, type in what you are looking for and get browsing.
If you know who wrote a particular comment or post then you can also use advanced search to narrow down your options.
Done the reset on the drive, one thing i have noticed straight away is the tick over is better, before it would idle at about 650 rpm, now its up in the correct region of 750.
going to give it blast up the road in ten minutes, see if its worked..
Gotta be worth a try when it doesn't cost you anything!
Let us know how you get on.
Best getting it in for a diagnostic check. Try an independent BMW garage rather than a stealer as it'll be a lot cheaper. At least it will give you piece of mind tracking exactly what the problem is. :P
Isn't the 316i cable throttle?
I believe the earlier models were, mine is a 2003, with the n42 valvtronic, its a 1.8i.
Although I am only going on what I have read on the internet.
Added below some gumpf from parkers site..
Production 4 Mar 2002 -31 Jan 2005
Length 4471 mm
Width 1739 mm
Height 1415 mm
Weight 1385 kg
Fuel Delivery Multi point fuel injection
Transmission Manual
Gears 5 Speed
Performance
Engine Size 1796 cc
Cylinders 4
0-60 mph 10.6 s
Power Output 114 bhp
Valves 16
Torque 175 Nm 129 lb-ft
Top Speed 128 mph
Latest update.
Had diagnostics done today, no faults recorded, but on further investigation reading the data it was noticed that the lambda sensor seems to not show signs of any fluctuation in readings, so signs are its knackered.
Chappy that done the test is going to have a look at it next week.
Any ideas how much a new sensor will cost? also, which make to go for? stealer's, or after market...
Go for OEM when it comes to stuff like sensors. Aftermarket ones tend not to be as reliable/last as long.
Update again..
After having the Lambda sensors checked to it turns out both are knackered, what are the chances of that!
Both were tested and both show no voltage or fluctuation changes.
Is it common for both to be faulty? or chances are one could have been faulty for a long time, and the other died more recent..post-1707-1245752482_thumb.jpg
