DG11LAM
Buying an E46
Sorry, I only check in on here once a week or so.
I'm guessing that you are looking for a 6 cylinder as not many people want a 4 cylinder.
Convertibles suffer the same issues as any other with:
Expansion tanks and radiators split
Cam cover and oil filter housing gaskets leak
Thermostats stick (usually open)
Water pumps fail/leak
Coolant pipes swell when old
Window regulators fail, especially relevant on convertibles as front windows drop to allow door to shut
With the convertibles specifically, check the roof goes up and down time after time and that it fully goes down and all the plastic covers are there and go into place as they should and are not loose.
Check every electrical button does as it should in case it got left out in the rain with the roof down a few times.
On a 330i or 330d if your crazy enough to buy an oil burner convertible and like the smell of diesel fumes, check the boot floor has not been torn/cracked. Google it, it's mainly an M3 thing but lesser cars have been known to do it.
Check the carpet is not wet anywhere to indicate a leak.
Kirkynut
I have a very nice 330Ci which is my second one and all of the above are spot on, had this one for over
6 years now with only a few problems but i did look around for a while before buying it, i paid over the odds
for it but it was way better than most i looked at. It had done 46,000 miles when i bought it in 2013.
It's an 04 and now done 78,000 miles, here's it's history to date, all the cooling parts are being replaced as
preventative action but the cap on the expansion tank does have a slight leak.
Dec 2013
New battery fitted and a new drivers door locking mechanism OE
May 2014
New front lower control arm bushes fitted OE along with oil & filters change
Shell Helix fully syn and rear brake pads.
Complete new drivers door mirror fitted due the common wiring ribbon breaking OE
April 2015
Passenger airbag recall done at Sytners
Oct 2015
Professionally refurbished both front brake calipers inc new pads and brake fluid change
March 2016
Oil level sensor OEM replaced along with oil & filter change
May 2016
Fitted 18" staggered fitment Racing Dynamics RD2 alloys 18x8 and 18x9
Dec 2016
Fitted the Stealth HID kit from HIDS4U, 35W 5000K
Sept 2017
Drivers airbag recall done at Sytners
Sept 2017
Replaced Cam cover seal kit OE, Crank case ventilation kit OE,
NGK BKR6EQUP plugs, pollen filter, air filter, front brake hoses
Sept 2017
Four wheel alignment done at Silverline wheels & tyres Warwick
Sept 2017
Wheels refurbished along with 4 new Vredestein Ultac Vorti tyres fitted, last 3 photos taken after the refurb with a brighter silver powder coat
Nov 2017
Gearbox ATF changed at Transmission Technology Knowle Solihull
Nov 2017
Key refurbished by the Master Locksmith
Dec 2018
Oil filter housing O ring replaced
Aug 2019
Discs & pads all round & hand brake shoes
Oct 2019
Radiator, Water pump & ECS Tuning Aluminium pulley, Expansion tank, sensor & cap, Viscous coupling, A/C belt, AUX belt, Tensioners, Pulleys, Hoses, Coolant
Edited by dunk1
