silverzx Posted January 9, 2020 Report Share Posted January 9, 2020 Hi guys! Firstly thanks for having me, I own few BMW's including this E46 I'm having issues with.. I've had this 52 plate (5 speed) 330Ci for almost a year now but it's been parked up a good few months as I've had an issue with the cluster. After the car was sat and went dead the cluster showed a “PPPPP” error upon charging and being started back up. The rev counter, speedo, fuel and water temp gauges all still worked however it seemed the speedo is also now over reading. Says I'm doing 60 when I'm actually doing about 45? I purchased a cable and installed NCS Expert. I had a go at re-coding the cluster based on some advice I received but had no luck and kept getting errors. On someone else's advice I tried to discharge the system by touching the positive and negative battery cable terminals together for 30s (obviously with the battery disconnected), since then the “PPPPP” error has gone and the mileage now displays 999,999. I haven't driven it since and ideally would like to return the mileage to the correct number as well as sort out the ABS light which was never lit before. Can anyone advise on what to do before I contact BMW directly? I'm quite tech savvy and happy to buy cables / recode if instructed correctly. Thanks in advance! Link to comment Share on other sites More sharing options...
silverzx Posted January 27, 2020 Author Report Share Posted January 27, 2020 BUMP. 😊 Link to comment Share on other sites More sharing options...
silverzx Posted February 2, 2020 Author Report Share Posted February 2, 2020 BUMP. Link to comment Share on other sites More sharing options...
dontpannic Posted February 6, 2020 Report Share Posted February 6, 2020 I would say the cluster was dead. If this wasn't caused by coding in the first place then I would assume the EEPROM is kaput. New cluster - PA Soft to write the VIN, coding and mileage to the new cluster and that should solve all of your issues. Link to comment Share on other sites More sharing options...
silverzx Posted May 24, 2020 Author Report Share Posted May 24, 2020 I ended up swapping out the cluster for one on very similar milage to the original, I have a tamper dot now but at least the milage displays again. Not exactly a win but not exactly a loss either. Link to comment Share on other sites More sharing options...
dontpannic Posted July 28, 2020 Report Share Posted July 28, 2020 PA Soft can write the correct VIN and mileage IIRC Link to comment Share on other sites More sharing options...
