sweetpea
Scary Moment
Hi all,
Had a jolly 'Up North' on Fri last week to collect something from a place called Blyth just north of Newcastle.
Anyway... as you know it Pi**** it down all day and the motorway journey was very poor with visibilty down to approx 100 yds.
It was whilst on the A1(M) that my wipers decided to stop!! yikes!
Fortunately there was a parking area not too far in the distance so i managed to scramble into there...... quite a moment when visibilty is zero.... i had to drive with my head out of the window ;) ... not to be recommended!
I parked up for a couple of minutes and checked fuses etc... as you do, but could find nothing obvious.
After a couple of minutes, the wipers started to work again of their own accord.
It happened twice again after this but fortunately on minor roads, so not a problem.
Thing is...... this has knocked my confidence on the motorway if raining, i keep thinking it could happen again, i was really lucky not to have been in the outside lane at the time! ;)
I have done a dig of digging on this and other forums and there is mention of the wiper motor overheating..... what do you think is this possible and if so, what can be done to check, or shall i just get it replaced anyway?
Any thoughts of other possible causes?
btw the wipers always parked in resting position never upright.
Thanks Mike :)
yikes!!
funny that ya had to stick ya head out the window but still... yikes!
if in doubt m8 i would either take it to local stealers
or just buy and replace the motors?!
Were they in auto-mode or normal mode?
If you rule out the rain sensor then it sounds more like a dodgy connection than a motor problem to me... the motors must be working to some extent in order to park the wipers, but possibly the signal from the wiper switch is getting lost.
And as a back-up plan, use some rain-x on your windscreen... (or does polish work just as well? O_o)
As above - oh and rain x is well worth the money you will spend on it, although not sure on polish would prob avoid sticking this on windows.
I've always had the same in the back of my mind after i eneded up with no working wipers on my old e36 beamer
This is what i now do so i know that if it does rain you can still see quite well at 50/60mph.
1: Wash your windows with a spounge and fairy liquid, Press hard on the window it helps loads to remove the top layer of grime and also make sure you use a fair bit and try not to get any washing up liquid on the body workif you do just rinse it off before it drys as washing up liquid is acidic and brasive when rubbed upon something.
2: Get some Farecla G3 rubbin compound. After time you windows will go streaky, (happens to the rear window) and you get a like glazed effect on the window when wet. use the G3 with a spounge and be very harsh on the window with it. Make sure you use water with the Farecla G3 as it will be abrasive on the glass. This really does take the crap off it :) If you think Farecla G3 is to harsh for the window, use Farecla G10. (I've never had an issue with Farecla G3 though, G10 is a lighter grade rubbing compound)
4. Wash the window again with washing up liquid and water just to make sure there is no G3 left on the windows or car body.
5. Rain-x your windows, (I used halfords home brand its about £5 less and still just as good!)
6. Polish up the windows with Farecla Liquid Wax Polish.
Jobs a good one, and the window looks as clean as ever!
(Just need to clean the inside now as you will see all the dust and finger prints if you've ever touch the inside!)
I do all the above on all my windows and i've gotta say if its raining i tend not to even use the wipers unless its really heavy as the rain just runs straight off.
Hope that helps!
- Dan.
Edit: In regards to the PM I recieved, Yes this will even remove the streeky marks that your wipers leave on the edge of your windscreen...
So you window will have no marks from where the wipers have been wiping.
You can use AG Super resin polish on glass , it will repel water , but not as much as Rainx ;)
The relays are known to overheat if left on auto mode. You can either change the relay or leave it on normal operation, as this is supposed to help. Mine has done it once and scared the sh*t out of me B) BMW have redesigned iirc, so now they are ok ;)
Cheers guys i appreciate all your thoughts and suggestions
In answer to some of them, the wipers were used on a mixture of settings, ie Permanently on or on auto.... so i think that rules out the rain sensor?
I think to start with, i will replace the relay.. any ideas where it is located and where i can source one?
Thanks
Mike ;)
In answer to sime of them, the wipers were used on a mixture of settings, ie permantely on or on auto.... so i think that rules out the rains sensor?
Thanks
Mike ;)
Dealer, but be warned they aint cheap iirc
Cheers Chris..... would i be correct in thinking the relay is located under the plastic cover at the RH rear of the engine beneath the windscreen ?
Any idea of cost?
Mike ;)
Called into the stealers... i was pleasantly surprised... £11 quid + vat for the relay
Will give that a go, hopefully will do the trick.
Will see
Mike :)
Will see
Mike :)
My memory is spot on :) Well at least you got a nice surprise :lol:
The relays are known to overheat if left on auto mode. You can either change the relay or leave it on normal operation, as this is supposed to help. Mine has done it once and scared the sh*t out of me :lol: BMW have redesigned iirc, so now they are ok :D
Crapola, this happened to me a few days ago... I do tend to leave it on auto...
So the new relay is redesigned to avoid the problem? If so it's gotta be worth £11 or so...
I made it to safe area and stuck my hazards on, only to get abused by some moron in a van because I wasn't supposed to "park" there... No **** Sherlock... :P
Not sure if they redesigned it :D But they work a lot better.
Just swapped mine... t'was a Siemens one that came out, and a Tyko(sp?) one that went in, same serial number etc., both have BMW label on them.
Though interestingly, while looking to verify I was swapping the correct relay, I came across this :-
http://www.boards.ie/vbulletin/showthread.php?p=56744384
Where they seem to think the problem is something else...
umm interesting. Seems like a common problem then, but mine seems ok since the new relay. And mine was a siemens one, but i put another siemens one back in. Reprogramming the ZME would be fun!
