Chimp Choker
Ncs Coding Options
ive pasted a screen dump of ALL options that are available in NCS Expert, (be aware your .trc file will depend on what is fitted to the car), so some options in the list below may not be available to you
as always use NCS expert at your own risk, damage can be done, and ALWAYS back up your ECU prior to coding
ill start with the most common, the GM, General Module
Generated with NCS Dummy version 0.5.0.5 — copyright © 2011 revtor software
Output : Module Functions
Chassis : E46
Module : GM5.C01
ID FUNCTION KEYWORD FUNCTION KEYWORD TRANSLATION
ID PARAMETER KEYWORD PARAMETER KEYWORD TRANSLATION
00BC SCHEIBENABSENK_OHNE_EKS
0001 aktiv active
0002 nicht_aktiv not active
04D2 SENSOR_REGEN RAIN SENSOR
0001 aktiv active
00BB ANLAUFSTROMBEGRENZ_MEMO STARTING CURRENT LIMITING MEMO
0001 aktiv active
04D4 HUB_VERZOEGERUNG_FH_VORN
0001 aktiv active
049F WISCHERINTERVALL WINDSCREEN WIPERS INTERVAL
003B 5_sec 5 seconds
0084 3_sec 3 seconds
04D3 STANDRUECKSCHALTUNG WIPERS RETURN TO INTERVAL WHEN CAR STOPPED
0001 aktiv active
00BA WISCHERPOTI WINDSCREEN WIPERS POTENTIOMETER TIMING
0001 aktiv active
04D1 SCHEINWERFERREINIGUNG HEADLIGHT CLEANING
0001 aktiv active
04E0 AUSSTELLFENSTER VENT WINDOW (???)
0001 aktiv active
04DF FH_ABSENKEN_VERDECK_OEFF LOWER POWER WINDOWS WHEN OPENING CONVERTIBLE TOP
0001 aktiv active
04DD FUNKTION_CABRIO CONVERTIBLE FUNCTION
0001 aktiv active
04DC FH_ABSENKUNG_SPERREN REVERSE POWER WINDOWS WHEN OBSTRUCTED WHILE CLOSING
0001 aktiv active
00BE E52_FUNKTIONEN E52 (Z8) FUNCTION
0001 aktiv active
00BD FH_NACH_TUERE_AUF POWER WINDOWS WHEN DOOR IS OPEN
0001 aktiv active
04DB FH_ABSCHALTKRITERIUM POWER WINDOWS BEHAVIOR AFTER IGNITION DEACTIVATED [uS: DISABLE, ECE: ENABLED FOR ANOTHER MINUTE]
0034 ece ece (europe)
0083 us usa
00C0 DIFFERENZ_ANLAUF_BLOCK
0007 wert_01 value 01
04E4 EINKLEMMSCH_REVERSIEREN JAM PROTECTION MOVE BACK
002B kurz short
0096 lang long
04E3 EINKLEMMSCH_HINTEN JAM PROTECTION REAR
0001 aktiv active
04E2 EINKLEMMSCH_VORNE JAM PROTECTION FRONT
0001 aktiv active
00BF FENSTERHEBER_VORNE FRONT POWER WINDOWS
0001 aktiv active
04E1 FENSTERHEBER_HINTEN REAR POWER WINDOWS
0001 aktiv active
00C5 FH_ZTR_SCHALTER_TIPP_ZU ALL-WINDOW BUTTON ONE-TOUCH CLOSE
0001 aktiv active
00C4 FH_ZTR_SCHALTER_TIPP_AUF ALL-WINDOW BUTTON ONE-TOUCH OPEN
0001 aktiv active
04E9 FH_TUEREN_HINTEN_TIPP_ZU ONE-TOUCH CLOSING REAR POWER WINDOWS
0001 aktiv active
00C3 FH_TUEREN_HINTEN_TIPP_AUF ONE-TOUCH OPENING REAR POWER WINDOWS
0001 aktiv active
04E8 FH_BEIFAHRERTUER_TIPP_ZU ONE-TOUCH CLOSING PASSENGER'S POWER WINDOW
0001 aktiv active
00C2 FH_BEIFAHRERTUER_TIPP_AUF ONE-TOUCH OPENING PASSENGER'S POWER WINDOW
0001 aktiv active
04E6 FH_FAHRERTUER_TIPP_ZU ONE-TOUCH CLOSING DRIVER'S POWER WINDOW
0001 aktiv active
00C1 FH_FAHRERTUER_TIPP_AUF ONE-TOUCH OPENING DRIVER'S POWER WINDOW
0001 aktiv active
00C7 ZEIT_TUER/SCHLIESSZEIT DOOR LOCK TIME
0008 wert_02 value 02
00C6 SCHEIBE_ABSENKZEIT
051E BEDIENSTELLE_BFT CONTROL UNIT PASSENGER SIDE DOOR
0001 aktiv active
00E0 EINSTIEGSHILFE EASY ENTRY (PUSHING REMOTE OPEN TWICE LOWERS DRIVERS WINDOW)
0001 aktiv active
04A0 ENTSICHERN_CENTERLOCK CENTRAL LOCKING BUTTON UNLOCKS WITHOUT KEYS IN IGNITION
0001 aktiv active
04F0 HECKSCHEIBE_ENTRI_INNEN HEATED REAR WINDOW (???)
0001 aktiv active
00C9 VERRIEGELN_AUT_NACH_2_MIN AUTOMATICALLY LOCK VEHICLE AFTER BEING UNLOCKED FOR 2 MINUTES WITHOUT OPENING A DOOR
0001 aktiv active
04EB FUNKTIONEN_TOURING TOURING FUNCTIONS
0001 aktiv active
00C8 VERRIEGELN_AUT_AB_X_KM/H AUTOMATICALLY LOCK VEHICLE WHEN EXCEEDING A CERTAIN SPEED (LINKED TO [VERRIEGELUNGSSCHWELLE])
0001 aktiv active
04EA ZV_SELEKTIV CENTRAL LOCKING ONLY UNLOCKS DRIVER'S DOOR ON FIRST UNLOCK
0001 aktiv active
00CF KOMFORTSCHLIE_FB_OHNE_SHD COMFORT CLOSING (POWER WINDOWS WITHOUT SUNROOF)
0001 aktiv active
04F1 KOMFORTSCHLIE_FB_O_FH_HI COMFORT CLOSING (POWER WINDOWS WITHOUT REAR SIDE WINDOWS)
0001 aktiv active
00CE HECKKLAPPEN_LOGIK TRUNK LID LOGIC
001B geschlossen closed
0273 offen open
00CD ABSCHALTUNG_VERBRAUCHER SHUT DOWN CONSUMER LOAD
0001 aktiv active
00CC IB_BEI_KL.R_AUS INTERIOR LIGHTS TURN ON WHEN IGNITION TURNED OFF AFTER DRIVING WITH HEADLIGHTS ON
001A aktiv_mit_kl.58 active with terminal 58 (license plate lights)
00CB IB_EIN_SCHLOSS_ENTRIEGELN INTERIOR LIGHTS TURN ON WHEN UNLOCKED
0001 aktiv active
00CA SOFT_ON/OFF SOFTLY FADE ON/OFF INTERIOR LIGHTS
0001 aktiv active
00D1 EINGANG_2_KONTAKT_GESCHL INPUT 2 CONTACT CLOSED
0001 aktiv active
00D0 EINGANG_2 INPUT 2
0001 aktiv active
0502 FUNKINNENRAUMSCHUTZ_HI INTERIOR SPACE MONITORING REAR
0001 aktiv active
04F5 FUNK_INNENRAUMSCHUTZ ULTRASONIC INTERIOR MONITORING
0001 aktiv active
04F4 NEIGUNGSGEBER TILT SENSOR
0001 aktiv active
04F3 DWA ANTITHEFT ALARM SYSTEM (DWA)
0001 aktiv active
04BC ALARM_OPT_FERNLICHT VISUAL ALARM (HIGH BEAMS FLASH)
0001 aktiv active
04FE ALARM_OPT_ABBLENDLICHT VISUAL ALARM (LOW BEAMS FLASH)
0001 aktiv active
04FA ALARM_OPT_WARNBLINKER VISUAL ALARM (HAZARD LIGHTS FLASH)
0001 aktiv active
04F9 ALARM_AKUSTISCH_LANG LONG ACOUSTIC ALARM
0001 aktiv active
04F8 ALARM_AKUSTISCH ACOUSTIC ALARM
0099 intervallton intermittent tone
009A dauerton continuous tone
04F7 SCHAERFEN/ENTSCHAERFEN LOCK AND UNLOCK
0097 schloss_und_fernbedienung with key and remote
0098 nur_mit_fernbedienung only with remote
04A2 QUIT_AKUST_ENTSCH ACOUSTIC REMOTE UNLOCKING ACKNOWLEDGE (TWO ALARM BEEPS)
0001 aktiv active
0501 QUIT_OPT_ENTSCH VISUAL REMOTE UNLOCKING ACKNOWLEDGE (TWO TURN SIGNAL FLASHES)
0001 aktiv active
04A1 QUIT_AKUST_SCHAERF_KLAPPE ACOUSTIC REMOTE LOCKING ACKNOWLEDGE LIDS CLOSED
0001 aktiv active
00D2 QUIT_AKUST_SCHAERF ACOUSTIC REMOTE LOCKING ACKNOWLEDGE (SINGLE ALARM BEEP)
0001 aktiv active
0500 QUIT_OPT_SCHAERF_KLAPPE VISUAL REMOTE LOCKING ACKNOWLEDGE LIDS CLOSED
0001 aktiv active
04FF QUIT_OPT_SCHAERF VISUAL REMOTE LOCKING ACKNOWLEDGE (SINGLE TURN SIGNAL FLASH)
0001 aktiv active
0507 IR_FERNBEDIENUNG INFRARED REMOTE CONTROL
0001 aktiv active
00D6 HKL_SPERREN_BEI_ZS DISABLE TRUNK LID BY CENTRAL LOCKING
0001 aktiv active
00D3 INNENLICHT_AN_MEHRFACH_ZV PRESSING REMOTE LOCK BUTTON TWICE TURNS ON INTERIOR LIGHTS
0001 aktiv active
04BD PANIK_MODUS PANIC MODE (TRIGGER ALARM WITH REMOTE)
0001 aktiv active
0506 KOMFORTSCHLIESSUNG_FB COMFORT CLOSING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP)
0001 aktiv active
04DE KOMFORTOEFFNUNG_FB COMFORT OPENING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP)
0001 aktiv active
0504 FERNBEDIENUNG REMOTE CONTROL
0001 aktiv active
00D4 VERZUG_PANIK_MODUS_0.2_S DELAY PANIC MODE 0.2 SECONDS
04EF HECKSCHEIBE_ENTR_SENDER_4
0001 aktiv active
04EE HECKSCHEIBE_ENTR_SENDER_3
0001 aktiv active
04ED HECKSCHEIBE_ENTR_SENDER_2
0001 aktiv active
04EC HECKSCHEIBE_ENTR_SENDER_1
0001 aktiv active
050B SEL_ZV_SENDER_4 SELECTIVE UNLOCKING WITH REMOTE KEY 4
0001 aktiv active
050A SEL_ZV_SENDER_3 SELECTIVE UNLOCKING WITH REMOTE KEY 3
0001 aktiv active
0509 SEL_ZV_SENDER_2 SELECTIVE UNLOCKING WITH REMOTE KEY 2
0001 aktiv active
0508 SEL_ZV_SENDER_1 SELECTIVE UNLOCKING WITH REMOTE KEY 1
0001 aktiv active
00E4 EINSTIEGSHILFE_SENDER_4
0001 aktiv active
00E3 EINSTIEGSHILFE_SENDER_3
0001 aktiv active
00E2 EINSTIEGSHILFE_SENDER_2
0001 aktiv active
00E1 EINSTIEGSHILFE_SENDER_1
0001 aktiv active
00D9 VERRIEGELN_XKM/H_SENDER_4 AUTOMATICALLY LOCK VEHICLE WHEN EXCEEDING A CERTAIN SPEED WHEN USING KEY 4
0001 aktiv active
00D8 VERRIEGELN_XKM/H_SENDER_3 AUTOMATICALLY LOCK VEHICLE WHEN EXCEEDING A CERTAIN SPEED WHEN USING KEY 3
0001 aktiv active
00D7 VERRIEGELN_XKM/H_SENDER_2 AUTOMATICALLY LOCK VEHICLE WHEN EXCEEDING A CERTAIN SPEED WHEN USING KEY 2
0001 aktiv active
00D5 VERRIEGELN_XKM/H_SENDER_1 AUTOMATICALLY LOCK VEHICLE WHEN EXCEEDING A CERTAIN SPEED WHEN USING KEY 1
0001 aktiv active
00DA WISCHER_RUECK_GESCHW REAR WINDOW WIPER SPEED
00DB EKS_OFFEN/UNTERBRECHUNG
00DC EKS_GEDRUECKT/OFFEN
00DD CODIERUNG_ERFOLGT_1 CODING 1 COMPLETED
001C codierung_erfolgt coding completed
ill add more as we go on, and only if the mods think this will work in this format
I'm tempted to maybe put this in a read-only google docs spreadsheet? Might be worth it in the long run, if you give me your trc files I can turn them into csvs and then import them into excel
sounds good, but my .trc files will only be good for a car with the same spec as mine
would it not be better to upload all the modules functions.txt files from NCS expert, and set each module as a seperate tab i.e
GM
FTM
BTM
LSZ
etc
other zoners could then use it as a quick guide to search for a particular setting to switch on\off, rather than using NCS dummy to covert for them?
just let me know, no issue either way
GM
FTM
BTM
LSZ
etc
yeah that would be ideal, i'm sure there's some way we could compare text files automatically too, would enable us to add options one person has that the other doesn't.
edit: this was the spreadsheet i was talking about: https://docs.google.com/spreadsheet/ccc?authkey=CJyaz_QG&key=0AnhS6mc0qh_MdEtLb2VDUmZJWTk5R0NmWWJHRXJWaXc&hl=en&authkey=CJyaz_QG#gid=0
Edited by analbeard
are there any guides to using NCS? I am happy to use INPA but never had the balls to boot up NCS.
I think Simon (Analbeard) is sorting a detailed guide out as we speak :)
How in user friendly is this software!!!
I have NCS & Dummies connected to the car I can read some of the modules with ncs & dummies but that's as far as I can get.
What I'd like to be able to do is:
Disable the oil level light
Tell the car it has xenons
Enable one touch close of the windows from the remote
With a bit of guidance I've changed some s**t!
Disabled the oil level sensor light (as I don't have one!)
Disabled the ACS warning light (as I don't have traction control)
I'd still like to be able to tell the car is has xenons but can't find that option yet.
0001 aktiv active
0001 aktiv active
Sent from my GT-N7100 using Tapatalk 2
