DJ Syxx
Anyone got a step by step on how to code LED rear lights
I coded my genuine LED rears with PA Soft, I pretty much turned off the hot and cold checks, and set the PVM value to FF. Been fine since, no bulb out warnings or flashing from the units.
Not used NCS Expert but there may be similar options.
Use Navcoder,you,d need to buy it but its only £19.66 and its really easy to use,literally 2 minutes.
I,d give you my code but it will only work on the machine you register it on i.e my laptop,likewise i,d do it for you but i,m in Lancashire.
Have a look at the link it shows exactly what boxes to tick to sort it,if you need any more info give me a shout
http://www.e46zone.com/forum/topic/57781-led-rear-lights-part-nos-and-what-you-needcoupe/#entry848803
Steve
Easy
Open NCSExpert
File
Load Profile
Expert Mode
FG/ZCS/FA
ZCS/FA f. ECU
E46
AKMB
Process ECU
ALSZ / LSZ
Change Job
CODIERDATEN_LESEN
Execute Job
Open NCSDummy
Browse (click the arrow)
Load FSW_PSW.TRC
Filter - Modules by Trace File
Change all the cold and hot monitorings of tails/rear brake/rear indicators to nicht_aktiv (not enabled)
Export FSW_PSW
Export FSW_PSW.MAN
Back to NCSExpert
Change Job
SG_CODIEREN
Execute Job
Turn car off, wait 10 seconds, turn car back on and test.
NOTE: BACK UP YOUR TRACE FILE AFTER RUNNING THE CODERDATEN_LESEN JOB. It's FSW_PSW.TRC in the NCSEXPERT\WORK folder. This means you can go back if you f**k up.
On 05/04/2015 at 00:51, dontpannic said:
Easy
Open NCSExpert
File
Load Profile
Expert Mode
FG/ZCS/FA
ZCS/FA f. ECU
E46
AKMB
Process ECU
ALSZ / LSZ
Change Job
CODIERDATEN_LESEN
Execute Job
Open NCSDummy
Load FSW_PSW.TRC
Export FSW_PSW
Export FSW_PSW.MAN
Back to NCSExpert
Change Job
SG_CODIEREN
Execute Job
Thank you verry much !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
