DJ Syxx Posted April 2, 2015 Report Share Posted April 2, 2015 Hi guys as per topic anyone know the coding procedure to code LED rear taillights. I know you have to code the LCM but need info on how you go about doing this with NCS Expert. Cheers. Link to comment Share on other sites More sharing options...
DelMonty Posted April 3, 2015 Report Share Posted April 3, 2015 I coded my genuine LED rears with PA Soft, I pretty much turned off the hot and cold checks, and set the PVM value to FF. Been fine since, no bulb out warnings or flashing from the units. Not used NCS Expert but there may be similar options. Link to comment Share on other sites More sharing options...
broonster Posted April 3, 2015 Report Share Posted April 3, 2015 Use Navcoder,you,d need to buy it but its only £19.66 and its really easy to use,literally 2 minutes. I,d give you my code but it will only work on the machine you register it on i.e my laptop,likewise i,d do it for you but i,m in Lancashire. Have a look at the link it shows exactly what boxes to tick to sort it,if you need any more info give me a shout http://www.e46zone.com/forum/topic/57781-led-rear-lights-part-nos-and-what-you-needcoupe/#entry848803 Steve Link to comment Share on other sites More sharing options...
DJ Syxx Posted April 3, 2015 Author Report Share Posted April 3, 2015 Thanks guys but not really a help. Anyone done this with NCS??? Link to comment Share on other sites More sharing options...
CharlE46 Posted April 3, 2015 Report Share Posted April 3, 2015 Drop Bungers, chimp or Triggerfish a PM, they all use NCS and should be able to walk you through it. DJ Syxx 1 Link to comment Share on other sites More sharing options...
Chimp Choker Posted April 3, 2015 Report Share Posted April 3, 2015 Hi. I've got a pdf on the diagnostic laptop for this. Pm me your email address and I'll ping it over later as on bank holiday lash at the moment DJ Syxx 1 Link to comment Share on other sites More sharing options...
DJ Syxx Posted April 3, 2015 Author Report Share Posted April 3, 2015 Going to PM you now Hi. I've got a pdf on the diagnostic laptop for this. Pm me your email address and I'll ping it over later as on bank holiday lash at the moment Link to comment Share on other sites More sharing options...
dontpannic Posted April 4, 2015 Report Share Posted April 4, 2015 Easy Open NCSExpert File Load Profile Expert Mode FG/ZCS/FA ZCS/FA f. ECU E46 AKMB Process ECU ALSZ / LSZ Change Job CODIERDATEN_LESEN Execute Job Open NCSDummy Browse (click the arrow) Load FSW_PSW.TRC Filter - Modules by Trace File Change all the cold and hot monitorings of tails/rear brake/rear indicators to nicht_aktiv (not enabled) Export FSW_PSW Export FSW_PSW.MAN Back to NCSExpert Change Job SG_CODIEREN Execute Job Turn car off, wait 10 seconds, turn car back on and test. NOTE: BACK UP YOUR TRACE FILE AFTER RUNNING THE CODERDATEN_LESEN JOB. It's FSW_PSW.TRC in the NCSEXPERT\WORK folder. This means you can go back if you f**k up. bmwtom, TriggerFish and CharlE46 3 Link to comment Share on other sites More sharing options...
fug Posted October 26, 2020 Report Share Posted October 26, 2020 On 05/04/2015 at 00:51, dontpannic said: Easy Open NCSExpert File Load Profile Expert Mode FG/ZCS/FA ZCS/FA f. ECU E46 AKMB Process ECU ALSZ / LSZ Change Job CODIERDATEN_LESEN Execute Job Open NCSDummy Browse (click the arrow) Load FSW_PSW.TRC Filter - Modules by Trace File Change all the cold and hot monitorings of tails/rear brake/rear indicators to nicht_aktiv (not enabled) Export FSW_PSW Export FSW_PSW.MAN Back to NCSExpert Change Job SG_CODIEREN Execute Job Turn car off, wait 10 seconds, turn car back on and test. NOTE: BACK UP YOUR TRACE FILE AFTER RUNNING THE CODERDATEN_LESEN JOB. It's FSW_PSW.TRC in the NCSEXPERT\WORK folder. This means you can go back if you f**k up. Thank you verry much !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
