Banny Posted June 30, 2015 Report Share Posted June 30, 2015 Running coilovers and as we all know the standard drop links are to long As recommended I used the Hyundai accent ones. Here's where my problem lies they are not man enough for the job, they are just too thin, because of this one of mine as snapped right by the ball joint is. So is there another manufacture that does something I can use that is more beefier as the Hyundai ones are not man enough for spirited driving. Link to comment Share on other sites More sharing options...
Rob- Posted June 30, 2015 Report Share Posted June 30, 2015 You can make your own with threaded bar and rose joints for not too much money. Sent a PM to autosri on this forum, pretty sure he knows how to do it. Link to comment Share on other sites More sharing options...
Banny Posted June 30, 2015 Author Report Share Posted June 30, 2015 I want something proper and substantial, not saying it's not, but would rather something better than threaded bar, a Hyundai one has broken on me. Link to comment Share on other sites More sharing options...
Rob- Posted June 30, 2015 Report Share Posted June 30, 2015 (edited) The reason it will have broken is because it's the wrong length. With threaded bar it can be adjusted to your exact needs so will be less likely to snap. You can get purpose made adjustable ones but you'll pay more for them. They will still use threaded bar for the adjustment though. Edited June 30, 2015 by Rob- StuBeeDoo 1 Link to comment Share on other sites More sharing options...
Jay. Posted June 30, 2015 Report Share Posted June 30, 2015 As above, there will be no tension on correctly adjusted adjustable droplinks StuBeeDoo 1 Link to comment Share on other sites More sharing options...
momo Posted July 1, 2015 Report Share Posted July 1, 2015 Hyundai Accent drop links? I thought the recommended ones were from the Hyundai coupe? Link to comment Share on other sites More sharing options...
Jay. Posted July 1, 2015 Report Share Posted July 1, 2015 as above Momo is right - Hyundai coupe rears Link to comment Share on other sites More sharing options...
Banny Posted July 1, 2015 Author Report Share Posted July 1, 2015 It was the coupe rears I used my bad putting accent. So they must of been right length, they are not thick enough can't see any other reason for them to to break as the length is fine, don't even have to really do much with ARB to fit them Link to comment Share on other sites More sharing options...
Banny Posted July 1, 2015 Author Report Share Posted July 1, 2015 I have been looking at these rose joints now, seem strong, wonder what size joint and threaded bar to go for Link to comment Share on other sites More sharing options...
StuBeeDoo Posted July 1, 2015 Report Share Posted July 1, 2015 but would rather something better than threaded bar If threaded bar with rose joints either end is good enough for race cars................. Link to comment Share on other sites More sharing options...
shafz Posted July 2, 2015 Report Share Posted July 2, 2015 It was the coupe rears I used my bad putting accent.So they must of been right length, they are not thick enough can't see any other reason for them to to break as the length is fine, don't even have to really do much with ARB to fit themi had the same issue, the hyundai ones are a bit too short, causing them bear too much load and bending them.Im running Peugeot 406 rear ones and so far so good...Ive seen these on ebay but not sure on qualityhttp://www.ebay.co.uk/itm/2-x-FRONT-ADJUSTABLE-SHORT-DROP-END-LINKS-FOR-BMW-E90-E91-E92-E93-/271894154276?pt=LH_DefaultDomain_3&fits=Plat_Gen%3AE46&hash=item3f4e278c24 Link to comment Share on other sites More sharing options...
Banny Posted July 2, 2015 Author Report Share Posted July 2, 2015 Just ordered two new Hyundai ones now, so they are gonna break are the pug ones slightly longer Link to comment Share on other sites More sharing options...
shafz Posted July 3, 2015 Report Share Posted July 3, 2015 Just ordered two new Hyundai ones now, so they are gonna break are the pug ones slightly longerthe pug ones are plastic ones.....160mm length...It was suitable for me, but not sure if it will be for you.tbh its probably more cost effective to buy an adjustable set rather than spending more and keep buying fixed length droplinks. StuBeeDoo 1 Link to comment Share on other sites More sharing options...
autosri Posted July 3, 2015 Report Share Posted July 3, 2015 M12 rod with m12 rose joints and 10mm reducers and 10mm bolts It's not to do with the strength the Hyundai ones are too short as the steering turns near full lock it's rotates them too much and binds up and causes them to snap StuBeeDoo and shafz 2 Link to comment Share on other sites More sharing options...
autosri Posted July 3, 2015 Report Share Posted July 3, 2015 Have you looked at mk1 focus links as there longer but may be too long for eBay cool overs Link to comment Share on other sites More sharing options...
Banny Posted July 4, 2015 Author Report Share Posted July 4, 2015 Ordered some adjustable ones in the end StuBeeDoo 1 Link to comment Share on other sites More sharing options...
StuBeeDoo Posted July 5, 2015 Report Share Posted July 5, 2015 Ordered some adjustable ones in the end Good call! Please post some pics when you get them, an opinion on the quality, and a link where you got them. Link to comment Share on other sites More sharing options...
Banny Posted July 5, 2015 Author Report Share Posted July 5, 2015 Ordered some adjustable ones in the end Good call! Please post some pics when you get them, an opinion on the quality, and a link where you got them. Will do, the proof is in the pudding as I do corner hard Link to comment Share on other sites More sharing options...
