yosam34
HELP PLEASE!!! Whistling, PPPP
Hi guys,
new here! need some help please.
I had a mad idea and purchased a 2002 330ci as my everyday car. I absolutely love it but it has a few problems that I am slowly working through.
Alternator failed so I have replaced this, since replacing there is a constant whistle at low RPM - when I disconnect the alternator the whistling stops - I am presuming that I have a dud alternator? I also have PPPPP or Code on the dash (I have tried leaving battery disconnected etc, the dash switches between PPPP & code).
I've put a new Bosch battery on as well, as the other was small & wedged in with cardboard. Pulling my hair out a bit.
Any advice greatly appreciated.
Many thanks
Sam
Your cluster needs to be reset. It can be done with software but i've heard this procedure works (taken from E46 Fanatics):
De Sisti said:
  • Turn key in ignition to position I
  • Remove fuses (10, 34, 43) for the dash
  • Re-insert the fuses (you'll hear a Whirring sound as you do so)
  • Turn key in ignition to position II
